Question about Maytag Performa PAV2200
How do I remove the top of a Maytag PAVT234AWW
I need to replace one of the springs at the bottom of my washing machine. How do I remove the top to access the spring area.?
  • 113 Answers
Between the front panel and the top there is a seam. On each side of the seam there is a clip. Take a putty knife and push on the clip. One is on the left and one on the right. Than just pull the top of the panel straight back and unhinge from the bottom. Hope that helps, Dave www.washermd.com
Posted on Dec 17, 2008
Where is my suspension spring on my washing machine
The suspension springs on your washing machine are used to either suspend the tub assembly from the cabinet or to stabilize the tub assembly to the washer base. They also absorb the vibration of the wash basket while the machine is in the spin cycle. Occasionally these springs will become damaged, stretched or detached which can cause excessive noise and vibration from your washer during the spin cycle. You will need to remove the top or front panel of the washing machine to gain access to the suspension springs. Inspect for stretching or damage and ensure that they are securely attached at both ends. Use caution when replacing the springs as they are under tension and always wear the proper protective clothing. We recommend that you replace all of the suspension springs if any are determined to be defective.
Jan 13, 2017 | Washing Machines
WE have a maytag preformer wash machine. Model #PAVT234AWW serial#10099602cv. The washer is level, but it still shakes bad when washing clothes, even after adjusting the load several times
Lift the top frame and check the grommets the suspend the drum, Open the lid and get a good grip on the front inside by the drum and give a good **** to open the top frame, the four grommets should be visiable in the corners. check to see if they are tight, if not replace them.
Feb 09, 2011 | Maytag Washing Machines
How do I adjust the belt on my maytag pavt234aww?? I read to shift the motor...but I tried to tighten the two screws on the bottom of the motor pivot slides and the motor keeps sliding around...what do I...
their is a crasy looking spring is it their i want you open another browser window and go to sears parts direct .com and enter your model number then show you a parts breakdown base should be part number one in diagram
Jan 28, 2011 | Washing Machines
How do i fit the drum suspension spring on my font loader ariston washing machine
If you have already remove the top cover, front cover and back cover of the washer. You can gain access to the bottom portion of the tumbler. There you can jack up the tumbler with a jack of some sort, so that the tumbler is higher easier to latch on the spring to the hooking holes and not have to struggle with the tension of the springs.thinkfixya.pnghen put them onto the hook holes.
Jan 10, 2011 | Ariston Technologies Washing Machines
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Maytag performa PAVT234AWW top load washer. The washer fills and spins fine. But when it is the wash cycle, the agitator makes a grinding noise and kind of vibrates in place. Is this something that can...
sounds to me like you have a bad transmission
what happens when you take the agetator off
does it still make the noise or does it go away?
if it goes away when you take the agetator off then you have a bad agetator
Aug 24, 2010 | Maytag Washing Machines
Door has no tension on it when opening it. It seems like a spring may be broke. How is the best way to go about checking it out and repairing it. Thanks Joey
Remove the front bottom access plate.
Look inside on the bottom right and left front corners for the spring and replace it in the grooves and slots from the door hinge to the cabinet base.
If the cabinet sides are in your way,you must remove the 2 screws mounting the machine to the underside of your counter top and pull the machine forward a few inches.
You should be able to do this without disconnecting water or power.
If the door spring is broken you will have to go to the appliance parts store in your area for another one.
Aug 14, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
How do I replace the oring gasket on a front loading samsung wash machine model number wf219anw/xaa
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Aug 11, 2010 | Samsung WF337AA Front Load Washer
Washing Machines Logo
410 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
