Question about Acer Aspire 5315 Notebook
Mouse works, click on icon, nothing happens
Mouse moves, click on any icon, including start button to shut down, and nothing happens? Took out battery to shut down.
Thanks in advance for any help.
    Genius:
  • 2,785 Answers
Its seems your os is havening problem try to restore to earlier date or repair it.
Posted on Dec 17, 2008
How do i reboot my toshiba laptop?
Procedure to reboot your Toshiba laptop may vary depending upon which version of Windows you are using. Refer to the steps below that match your Windows version:
For Windows 8:
If there's a Power icon on your Start screen, tap or click it, and then tap or click "Restart". Else, follow the steps below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Tap or click "Power", and then tap or click "Restart".
For all other Windows versions:
1. Click the "Start" button
2. Click the arrow next to the Shut Down button
3. Click "Restart"
OR
1. Click "Start" button
2. Click "Shut Down"
3. Select "Restart" in the drop-down menu below "What do you want the computer to do?"
GuruAid.com
Jun 25, 2014 | Acer Computers & Internet
How does the Staples wireless optical mouse B219 work
press the button on the wireless station then press the button on the mouse it should see it if it doesn't then you may need a new mouse. you can also test the batteries to make sure they have 1.5 v
Apr 08, 2017 | Innovera Computers & Internet
My touch pad works with a mouse,but when I tap my touch pad nothing happen's,thats when I lef click my mouse,it will move the icon,but wont tap on toanything
This has happened to me and it took me hours to figure it out. I hope yours is the same problem...
Make sure you dont have your touch pad set to off. On my ASUS It is F9 on my keyboard. the key shows an icon of the touch pad with a slash (/) through it. If you do not see this on your keyboard try looking in control panel and see if there is a setting in there. Good Luck. Please let me know if this worked.
Geraldine
Nov 18, 2011 | Computers & Internet
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Your problem lies only in mouse. All procedures followed are correct, but take a close look at the bottom of mice where the receiver is placed when not in use, look for a tiny thin button that protrudes from one of the sides, it has to be depressed while receiver is out, it might be stuck, try to press it down gently a couple of times, it must come out. If it doesn't work, take off battery, now press down mentioned button and release it immediately upon inserting back the battery. Hope will work ok. Good luck!! Chawah.
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
I have a logitech wireless mouse, i don't have the manuel or anything that came with it and i'm trying to connect it to my home desktop computer.. the piece that connects to the computer works the lights...
Click on the connect button on the remote (part connected to the PC) and click on the connect button on the mouse. Move the mouse around after you press that button. It should connect.
Also make sure your batteries are fresh.
Once working, I've found that Microsoft's Intelli mouse driver does a better job then Logitech drivers.
Jul 25, 2008 | Computers & Internet
Acer Aspire 5315 Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
