Question about Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size Gas Dryer - Arctic Blue/Chrome
Maytag Epic dryer won't start
The control on button works and shows time and dryer heat, but when I push the button it just beeps. The door is firmly shut.
  • 7kids537 Dec 17, 2008
    No, the dryer doesn't make any sound except for the beep when I push start.
  • Anonymous Mar 21, 2014
    Dryer has no heat
    Sergeant:
  • 409 Answers
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
  • Carmen Mikulic Dec 18, 2008
    than it's definitely the control board. i would recommend replacing it.
The dryer does not work. Error code 6 flashes appears.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 05, 2015 | Dryers
Why won't my dryer work?
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Aug 23, 2014 | Dryers
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
My maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Oct 24, 2012 | Maytag Dryers
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size Gas Dryer - Arctic Blue/Chrome Logo
2,090 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
