I have a head set-860, when I connect it with my computer , it does not work.
    President:
  • 8,637 Answers
Not sure if this will help but on the sound card the GREEN jack is for the earphones (or speakers) and the PINK jack is for the microphone.
If you need additional assistance let me know.
Bud
Posted on Jan 31, 2009
How to fix clogged ink from a epson stylus 860
try cleaning print/cart and print heads with achol and que tips
Jan 26, 2013 | Kodak EASYSHARE 5300 All-In-One InkJet...
1976 Ducati 860 GTS - backfire
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Backfiring
http://www.ducatimonster.org/forums/general-monster-forum/202081-exhaust-backfire.html Ducati 860 GTS GT 1976 1999 Service Repair Manual Download Manuals...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 04, 2012 | 1976 Ducati 860 GTS
The speaker of my vaio laptop is does'nt working only the head set one .
If you have head set connected to computer the computer speaker will be functioning thorough head set and you will not hear sound from computer. When head set is disconnected the computer speaker will function, just like usual!
Sep 17, 2011 | Sony Computers & Internet
Can I Connect both Poweredge 860 NICs to the same switch? It seems like they are setup to be redundant.
Yes, you can connect both NICs to the same switch. They each will have a unique IP address but will speed up your connection.
Good Luck
C2Solutions
Jul 02, 2010 | Dell PowerEdge 860 (becwnk1_7) Server
Laptop does not recognize magellan 860t when connected to usb port Magellan POI file editor issues message "no unit detected".
assuming your using a known good usb cable, you need to use windows XP sp2 or greater to install any magellan. if you are using that os or greater, try a different usb port.
if that fails, restart the computer and try again.
you can also try and reset the 860 using the reset on the top and see if that will help.
if none of those work, turn the reset button to the off position till the 860 goes off then plug in the usb cable and restart the 860.
if your not using windows XP sp2 or greater, hopefully you have a friend that does.
Nov 09, 2009 | Magellan RoadMate 860T GPS Receiver
Camera doesn't come on when I try to activate installation.
sotware for cameras dont work for apple unless in UVC mode means plug and play. here is a list of cameras compatiable to apple computers.
amera Name P/N QuickCam E3500/E3560 860-000095 QuickCam Ultra Vision SE 860-000023 QuickCam Ultra Vision 861238 QuickCam Orbit/Sphere MP 861305 QuickCam Fusion 861304 QuickCam Pro 5000 861306 QuickCam Pro 9000 861464 QuickCam Pro for Notebooks 860-000026 QuickCam for Notebooks Pro 861303 QuickCam Communicate MP (S5500) 860-000106 QuickCam Communicate Deluxe (S7500) 860-000107 QuickCam Communicate Deluxe 861235 QuickCam Deluxe for Notebooks 860-000009 QuickCam Vision Pro for Mac 860-000143
QuickCam Orbit AF 860-000063
Jul 11, 2009 | Logitech Quickcam Chat Webcam
I cannot set up wireless connection to my printer.
Check your drivers. Or go to the Canon site and download the latest ones.
Jul 07, 2009 | Sony VAIO K45 Notebook
Nec superscript 860 printer driver
Hi Richard,
As you might all ready know, this printer is not supported by Vista,  pasible solution: - if you have another "old" computer, you could install your printer on that, and share it, that way you can printe via the other computer. in case you want drivers for all other software, here is the link.
regards /Teis
Jan 07, 2009 | NEC SuperScript 860 Laser Printer
700p bluetooth set up with Sanyo GPS 4050
I got the pairing code via searching the internet it is 0000 and worked just fine. Now however I get an "Unable to connect message". Sanyo tech support is very hard to get a hold of.,.
May 12, 2008 | Sanyo NVM-4050 GPS Receiver
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
