Question about Whirlpool MH7130XE Microwave Oven
The door glass has a burnt discolored area
The lower glass of the door has a burnt discolored area that has increased in size with use
  • 2 more comments
  • djohnst513 Jan 13, 2009
    The door glass has a burnt discoloration area on the bottom. It is Model MH6150XHB-1 but is not included any any recalls. It has grown over the course of a couple of years. The inside of the door has a plastic sheeting over the window. In these areas it seems to have air bubbles. Can this hurt anything? Also, the turntable has not worked in about 3 years.
  • regattakid Jan 19, 2009
    I've had the same issue of discoloration in the door on Model MH6141XKQ, for the past several years. It appears to be a reaction from steam from cooking on the stovetop. We got it in 2002. A few days ago it stopped heating, and the turntable no longer rotates. Buttons, fan, light all still work. Not sure if the problem is related. Will let you know if I find out it is.
  • regattakid May 11, 2010
    Also would like to know if this is fixable, or should I just start looking for a new microwave?
  • William Miller
    William Miller May 11, 2010
    Is any of the plastic of the door frame melted or deformed?
    Is there any arcing or charring?
    Can you post a photo?
    What is your model number?
    Scholar:
  • 145 Answers
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
No power dead
power outages cause power surges and will damage electronic control boards. I suggest replacing the Control board and checking the interlocking door switches. Whilst inside the microwave check the magnetron for discoloration around the magnetron horn or gun as it were. If it don't look clean and new, otherwise burnt it's bad !
Feb 06, 2014 | Sharp Microwave Ovens
Need to know correct size of microwave door glass for LG model MG-604w mine is broken after a fall, can I still use without glass?
NO, do not use the microwave with a broken door glass, this glass is specially protected to stop any dangerous microwave leakage, it is also something you cannot replace yourself, take it to a reputable service centre so that once the glass has been repaire the oven can be tested for safety purposes.
Sep 09, 2013 | LG Over-the-Range Microwave
Can you use a microwave if the glass on the door is broken?
It is not advisable. The door is a critical safety part of the microwave oven. The glass being gone will allow heat in areas of the door not designed for heat. The glass also is a support for the safety mesh that contains the microwave energy to the cavity.
May 12, 2010 | Westpoint TV-201 Microwave Oven
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace a blown bulb
  • check the size of the bulb required before you buy a replacement bulb. Most use a 40 watt appliance bulb. I
  • Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Open the oven door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back then Gently remove either the wire clip or ring. Since the cover is most likely glass, be careful then Unscrew the entire glass cover similar to a jar lid in older versions of ovens. repeat process if there is more than one bulb..hope this helps pls do let me know
  • Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Broken glass on full sized microwave door
    Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
    LG LRM1230W Replacement Part Complete Door Assembly
    Jan 07, 2009 | LG LRM1230W Microwave Oven
    Microwave oven flashed and groaned, staining cover of waveguide
    I suspect the water content of the frankfurther was your issue. Operating a mwave at full capacity without adequate load to absorb energy would cause something like this to occur. Ultimately the energy had to go somewhere, it chose the weakest point to dissapate. You mention to glasses of water heated up fine? Then no worrie if theres no additional funny noises.
    Suggest you lower the power level to around 25% to cook a furter. :o) Or put a mug of water in with it.
    Dec 10, 2008 | Microwave Ovens
    Glass front on door unglued
    First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
    Dec 18, 2007 | Maytag MMV1153A Microwave Oven
    Need glass replacement, what is part number or size
    Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
    Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
    Burnt stain on door
    In most cases you must replace the glass in the door. Sorry i couldnt be of more assistance. Good Luck
    Jul 03, 2006 | Roper MHE14XKB Microwave Oven
    Whirlpool MH7130XE Microwave Oven Logo
    486 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
