Communication what is modulation in communication
  • rameshrai Jun 08, 2012
    modulation means to impress message signal(human voice for example) onto carrier signal(900MHz for example in GSM), AM modulation is the simplest modulation. you can see the link below how AM modulation is done with real voice input signal recorded with windows recorderhttp://blog.ektel.com.np/2012/06/amplitu...
    Novelist:
  • 152 Answers
To modulate the signal just means to systematically vary one of the three parameters of the signal: amplitude, frequency or phase. Therefore, the type of modulation may be categorized as either AM: amplitude modulation FM: frequency modulation or PM: phase modulation
Posted on Dec 17, 2008
U 1900 on 2007 Ford 6.0L Diesel 350 Super Duty
U1900 CAN Communication Bus Fault - Receive Error ABS Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault - Receive Error Instrument Cluster REFER to Section 418-00 . U1900 CAN Communication Bus Fault - Receive Error TBC Module REFER to Section 418-00 .
Your best bet , have a qualified technician diagnose it .
Communications Network Vehicle communication utilizes a high speed controller area network (HS-CAN), International Standards Organization (ISO) 9141 network and universal asynchronous receiver-transmitter (UART)-based protocol (UBP) network. Information is sent to and from individual control modules that each control specific functions. All 3 networks are connected to the data link connector (DLC). The DLC can be found under the instrument panel between the steering column and the audio unit.
The 3 module communication networks are:
  • High speed (HS) CAN
  • ISO 9141
  • UBP
ISO 9141 is for diagnostic use only while UBP and CAN allow multiple modules to communicate, or transfer data, with each other on a common network.
Module Name Network Type Termination Module Anti-lock brake system (ABS) module HS-CAN No Electronic automatic temperature control (EATC) module (if equipped) UBP N/A Instrument cluster (gateway module) HS-CAN and UBP Yes Parking aid module (PAM) (if equipped) ISO 9141 N/A Powertrain control module (PCM) HS-CAN Yes Restraints control module (RCM) ISO 9141 N/A Trailer brake control (TBC) module (if equipped) HS-CAN No Vehicle security module (VSM) (if equipped) UBP N/A Four wheel drive (4WD) control module (if equipped) ISO 9141 N/A
ISO 9141 Network Operation
The ISO 9141 communication network is a single wire network, used for diagnostic purposes only.
The ISO 9141 communication network is used for the following modules:
  • Parking aid module
  • RCM
  • 4WD control module
UART-Based Protocol (UBP) Communication Network
The UBP communication network is a single wire network. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The UBP communication network is used for the following modules:
  • EATC
  • Instrument cluster
  • Vehicle security module
HS-CAN Network Operation
The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The HS-CAN is a high speed communication network used for the following modules:
  • ABS module
  • PCM
  • Trailer brake control module
Network Termination
The CAN network uses a network termination circuit to improve communication reliability. The network termination of the CAN bus takes place inside the termination modules by termination resistors. Termination modules are located at either end of the bus network. As network messages are broadcast, in the form of voltage signals, the network voltage signals are stabilized by the termination resistors. Each termination module has a 120 ohm resistor across the positive and negative bus connection in the termination module. With two termination modules on each network, and the 120 ohm resistors located in a parallel circuit configuration, the total network impedance, or total resistance is 60 ohms.
Network termination improves bus message reliability by:
  • stabilizing bus voltage.
  • eliminating electrical interference.
Gateway Module
The instrument cluster is the gateway module, translating HS-CAN to MS-CAN and vice versa. This information allows a message to be distributed throughout both networks. The instrument cluster is the only module on this vehicle that has this ability.
ford netwok can bus-2uhxiqm5o1jvjooefixijuhm-4-0.gif All you need to do is find out which module isn't communicating
Communication Network Diagnostic Trouble Codes (DTC) Index NOTE: DTC U1900 will set in a module that is reporting a communication fault from another module on the data bus. The module that reports the fault is not the problem module. DTC Description Source Action U0073 Control Module Communication Buss Off ABS module DTC U0073 indicates the module could not communicate on the network at a point in time. The fault is not currently present. CLEAR the DTC. REPEAT the network test with scan tool. U0073 Control Module Communication Buss Off Instrument cluster DTC U0073 indicates the module could not communicate on the network at a point in time. The fault is not currently present. CLEAR the DTC. REPEAT the network test with can tool. U1900 CAN Communication Bus Fault-Recieve Error ABS module For module that failed network test, GO to Symptom Chart . U1900 CAN Communication Bus Fault-Recieve Error Instrument cluster For module that failed network test, GO to Symptom Chart . U1900 CAN Communication Bus Fault-Receive Error TBC module For module that failed network test, GO to Symptom Chart . U1950 UBP Communication Bus Fault Vehicle security module For module that failed network test, GO to Symptom Chart . U2023 Fault Received From External Node Instrument cluster RETRIEVE and FOLLOW non-network DTCs from other modules. REFER to Section 419-10 . U2226 UBP Invalid Data From Node ID $10 (PCM) Vehicle security module RETRIEVE and FOLLOW non-network DTCs from the PCM. REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. All other DTCs - - REFER to Section 419-10 .
Sep 22, 2018 | Ford Cars & Trucks
Have a 2005 ford expedition with 5.4 l eng its throwing code u1900 . what is this
U1900 CAN Communication Bus Fault Vehicle Security Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault 4WD Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Parking Aid Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error DSM REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Instrument Cluster If the 4X4 light is not flashing at key ON, REFER to Section 418-00 .
If the 4X4 light is flashing at key ON, REFER to Section 308-07A . U1900 CAN Communication Bus Fault-Recieve Error Power Liftgate Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Stability Assist Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Recieve Error Air Suspension Module REFER to Section 418-00 .
which module won't communicate ? need a up scale scanner to communicate with all the modules on the vehicle. Do you know what C.A.N - controller area network is ? Serial data bus (network) All the modules on the vehicle share data on the network . U code's indicate a problem with the network .
Aug 08, 2018 | Ford Cars & Trucks
Where is the hdm module on 2006 monte carlo ltz
HDM module ??????? No such module .
DTC U0100 00: Lost Communication With Engine/Powertrain Control Module (ECM/PCM)
DTC U0101 00: Lost Communication With Transmission Control Module (TCM)
DTC U0121 00: Lost Communication With Electronic Brake Control Module (EBCM)
DTC U0140 00: Lost Communication With Body Control Module (BCM)
DTC U0151 00: Lost Communication With Restraints Control Module
DTC U0155 00: Lost Communication With Instrument Panel Cluster (IPC) Control Module
DTC U0164 00: Lost Communication With HVAC Control Module
DTC U0168 00: Lost Communication With Vehicle Theft Deterrent (VTD) Control Module
DTC U0170 00: Lost Communication With Passenger Presence System (PPS)
DTC U0184 00: Lost Communication With Radio
DTC U0186 00: Lost Communication With Audio Amplifier
DTC U0194 00: Lost Communication With Digital Radio Receiver (DRR)
DTC U0198 00: Lost Communication With Communication Interface Module (OnStar®)
DTC U0209 00: Lost Communication With Heated Seat Module (HSM)
DTC U0214 00: Lost Communication With Remote Function Actuation (RFA)
These are all the modules onyour vehicle - no hdm module .
Oct 13, 2017 | Cars & Trucks
I've got a 2001 Cadillac deville and it says it's lost the IRC ID and IRC data code. any idea how that happen?
When a malfunction such as an open fuse to a module occurs while modules are communicating, a DTC U1001-1254 Loss of 000 Communications is set current. When the modules stop communicating the current DTC U1001-1254 Loss of 000 Communications is cleared but the history DTC remains. When the modules begin to communicate again, the module with the open fuse will not be learned by the other modules so U1000 or U1255 is set current by the other modules. If the malfunction occurs when the modules are not communicating, only U1000 or U1255 is set. Radio quit working shows Code IRC U1000 please help
Dec 07, 2016 | 2001 Cadillac DeVille
I have a 2003 bonniville sle i have a code U1040. Where is the EMCM AND PCM LOCATED
U1040
DTC U1001-U1254 IPC, PCM, SDM
040
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for 5 seconds, a DTC U1??? where ??? is equal to the 3-digit identification number is set.
Control Module
ID Number
Powertrain Control Module (PCM)
016
040
Dash Integration Module (DIM)
064
HVAC Control Module or IPM
065
Rear Integration Module (RIM)
066
Inflatable Restraint Sensing and Diagnostic Module (SDM)
088
096
Head Up Display (HUD)
098
Radio
128
Remote Playback Device - CD Changer
130
137
Vehicle Communication Interface Module (VCIM)
151
Driver Door Module (DDM)
160
Front Passenger Door Module (FPDM)
161
Left Rear Door Module (LRDM)
162
Right Rear Door Module (RRDM)
163
Memory seat Module (MSM)
166
Driver Door Switch Assembly (DDSA)
170
Remote Control Door Lock Receiver (RCDLR)
176
Theft Deterrent Control Module
192
The electronic brake control module is communicating , no need to bother the PCM . The code was set in pcm because it lost communication with EBCM , PCM not the problem .
Left Front lower corner of the engine compartment, under the air cleaner housing .
Check power's an ground's . Will a scan tool talk to it ?
Oct 03, 2016 | Cars & Trucks
What are the probable causes of DTC U1000?
DTC U1000 and U1255
Class 2 Communication Malfunction , Do you know what class 2 serial data communication network is ? What module set this code an what kind of scan tool did you use to read this code .
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the ID number of the module which sent the message for State of Health monitoring, Node Alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an ID number with at least one critical parameter within about 5.5 seconds of beginning serial data communication, DTC U1000 or U1255 is set. When more than one critical parameter does not have an ID number associated with it, the DTC will only be reported once.
The table below list the modules on the Class 2 Serial Data Circuit that will set a U1000 or U1255 and should be actively communicating the previously described messages on the Class 2 Serial Data Circuit.
Control Module
ID Number
064
040
096
Radio
128
016
088
Diagnostic Aids
When a malfunction such as a open fuse to a module occurs while modules are communicating, a Loss of Communication DTC is set as current. When the modules stop communicating, ignition is turned off, the current Loss Communication DTC is cleared but the history DTC remains. When the modules begin to communicate again, the ignition is turned on, the module with the open fuse will not be learned by the other modules so U1000 or U1255 is set current by the other modules. If the malfunction occurs when the modules are not communicating, only U1000 or U1255 is set.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
  1. A DTC U1001 - U1254 Lost Communications with with a history status may indicate the cause of U1000 or U1255.
  2. The modules not communicating are the likely cause of U1000 or U1255. The modules that are available on the class 2 serial data circuit are listed in the Circuit Description.
  3. The module which was not communicating due to a poor connection to the class 2 serial data circuit may have set DTC U1001 - U1254 Lost Communications with for those modules that it was monitoring.
  4. The modules which can communicate indicate the module which cannot communicate. You must clear the serial data communication DTCs from these modules to avoid future misdiagnosis.
  5. If all modules are communicating, the module which set U1000 or U1255 may have done so due to some other condition.
  6. The module which set U1000 or U1255 is the likely cause of the malfunction.
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Record the DTCs set in each module. If using a Tech 2, use the Class 2 DTC Check feature to determine which modules have DTCs set.
Did you record any DTCs in the range of U1001-U1254 with a history status?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 2
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to communicate with each module on the class 2 serial data circuit. If using a Tech 2, obtain this information using the class 2 Message Monitor feature.
  3. Record all of the modules communicating on the class 2 serial data circuit.
  4. Compare the list of modules which are communicating to the list given in Circuit Description.
Does any module on the class 2 serial data circuit not communicate?
YES - Go to Step 3
NO - Go to Step 12
Test the following circuits of the module that is not communicating for an open or short to ground:
The battery positive voltage supply circuits
The switched battery positive supply circuits
The battery positive voltage output circuits
The ignition voltage input circuits
The ignition voltage output circuits
Refer to the following:
Control Module References in Body Control System for the applicable schematic
Circuit Testing in Wiring Systems
Wiring Repairs in Wiring Systems
Did you find and correct the condition?
5
Important: Inspect all connectors in the serial data communications circuit.
Data Link Connector Schematics
Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Connector Repairs in Wiring Systems
  1. Turn OFF the ignition.
  2. Test the class 2 serial data circuits of the module that is not communicating for an open. Refer to the following:
Go to Step 8
Go to Step 6
6
Inspect the harness connector of the module that is not communicating for poor connections and terminal tension at the following circuits:
The battery positive voltage input circuits
The switched battery positive voltage supply
The ground circuits
The class 2 serial data circuits
Go to Step 8
Go to Step 7
7
Important: Perform the module programming or setup procedure if required.
Replace the module that is not communicating. Refer to Control Module References in Body Control System for the appropriate Repair Instructions for the module replacement.
Did you complete the replacement?
Go to Step 10
8
  3. Select the Display DTCs function for the module which was not communicating.
Does the scan tool display any DTCs which do not begin with a "U"?
Go to Control Module References in Body Control System for applicable Diagnostic System Check
Go to Step 9
9
Use the scan tool in order to clear the DTCs.
Did you complete the action?
Go to Step 10
10
Select the Display DTCs function for the modules which had U1000 or U1255 set as a current DTC.
Does the scan tool display DTCs which do not begin with a "U"?
Go to Step 11
11
System OK
12
Did you record any other DTCs for the modules which had U1000 or U1255 set as a current DTC?
Go to
Go to Step 13
13
  3. Use the scan tool in order to clear the DTCs.
  4. Turn OFF the ignition for at least 5 seconds.
  5. Turn ON the ignition with the engine OFF.
  6. Select the Display DTCs function.
Does the scan tool display U1000 or U1255 set as a current DTC?
Go to Step 14
Go to Diagnostic Aids
14
Replace the module which had U1000 or U1255 set as a current DTC. Refer to
System OK
Mar 12, 2016 | 2002 Pontiac Grand Am GT1
Where is the Body Control Module located?
I'm just curious if your aware of the BCM function's on your vehicle an if you know what the gate way module is ? An do you know about serial data communication between modules ? An do you know what the power mode master is ? And do you know the BCM needs programming ?
The body control module (BCM) in this vehicle functions as a gateway or translator. The purpose of the gateway is to translate serial data messages between the GMLAN high speed buss and the GMLAN low speed buss for communication between the various modules. The gateway will interact with each network according to that network's transmission protocol.
One example of this necessary communication is the communication between the engine control module (ECM)/powertrain control module (PCM) which is high speed serial data and Theft Deterrent Module which is low speed serial data. If these modules can not exchange information, the vehicle will not start.
Communication between the BCM and a scan tool can be on the high speed GMLAN network or low speed GMLAN network. If one network is lost, the BCM can still communicate with the scan tool. A lost communication DTC typically is set in modules other than the module with a communication failure.
Mar 04, 2016 | 2007 GMC Yukon XL Denali
I have multiple codes instrument cluster codes: u1073, u1262, u1059, u1123, u1041; ABS/TCS codes: u1073, u1262, C1805, B2900;
Did you change any modules on the vehicle ?
B2900 VIN Mismatched ABS Module VERIFY that the module has the correct as-built data.
CHECK for correct powertrain control module (PCM) and ABS module configuration using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 303-01A or Section 303-01B for the PCM. CLEAR the DTC. REPEAT the C1805 Mismatched PCM and/or ABS/TC Module ABS Module CHECK for correct PCM and ABS module configuration using the diagnostic tool. RECONFIGURE the component as necessary. FOLLOW the diagnostic tool directions for the ABS module configuration or REFER to Section 303-01A or Section 303-01B for the PCM. CLEAR the DTC. REPEAT the self-test. U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant PCM REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. U1262 SCP (J1850) Communication Bus Fault Network Fault REFER to Section 418-00 . Can a scan tool communicate with all the modules on the vehicle ?
  • The anti-lock brake system (ABS) module or stability assist module (if equipped) does not respond to the diagnostic tool
  • Circuit or connection in the standard corporate protocol (SCP) network.
  • ABS module.
  • Go To Pinpoint Test A .
U1123 Invalid or Missing Data For Odometer Instrument Cluster Go To Pinpoint Test G . U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/PRNDL PCM REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual. U1041 SCP (J1850) Invalid Or Missing Data For Vehicle Speed Instrument Cluster REFER to Section 413-01 . U1041 SCP (J1850) Invalid Or Missing Data For Vehicle Speed Tire Pressure Monitoring System Module REFER to Section 204-04 . You need to take it to the dealer , not a transmission shop. Your vehicle could have a ground issue , could have power issue , could have a control module issue . It needs to be hooked up to the factory scan tool ! It is for sure it has a communication problem on the SCP data bus , do you know what serial data communication is ?
The vehicle has 3 module communication networks:
  • the standard corporate protocol (SCP) communications network
  • the international standards organization (ISO) 9141 communications network
  • the universal asynchronous receiver-transmitter (UART) based protocol (UBP) communications network
The diagnostic tool connects to all 3 networks through the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one diagnostic tester to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the radio.
The SCP communications network will remain operational even with the severing of one of the bus wires. Communications will also continue if one of the bus wires is shorted to ground or voltage, or if some but not all termination resistors are lost. The SCP communications network allows inter-module communication.
The ISO 9141 communications network does not permit intermodule communication. When the diagnostic tool communicates to modules on the ISO 9141 communication network, the diagnostic tool must request all information, or initiate module commands.
The ISO 9141 communications network will not function if the wire is shorted to ground or battery voltage. Also, if one of the modules on the ISO 9141 communications network loses power or shorts internally, communications to that module will fail.
The UBP communications network will not function if the wire is shorted to ground or voltage. The UBP is different from the ISO communication network in that it allows intermodule communication.
Sep 13, 2015 | 2004 Lincoln Aviator
I have 08 ford escape when I try to scan it said no communication
Do you know about communication networks or serial data communications on vehicles , these let the scan tool communicate with the different modules on the vehicle ! Newer vehicles have several, PCM - powertrain control module , Anti-theft module , Air bags , antilock brakes , Body control module or in the case of ford a smart junction box . an some others !
Communications Network Vehicle communication utilizes both International Standards Organization (ISO) 9141 and controller area network (CAN) communications. ISO 9141 is used for diagnostic use only, and CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
  • ISO 9141
  • Medium speed (MS) CAN
All 3 networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
The HS-CAN network communicates using bussed messages. The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
  • ABS module
  • 4WD control module (if equipped)
  • PCM
  • MS-CAN Network Operation
    The MS-CAN network communicates using bussed messages. The MS-CAN has an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
    The MS-CAN is a medium speed communication network used for the following modules:
    • SJB
    HS-CAN Network
  • What type of scan tool are you using ? or are you using a code reader ?
  • What
Computer No Communication Troubleshooting by Wells Saturn Toyota Echo No Communication Case Study
Mar 18, 2015 | 2008 Ford Escape
98 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
