Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
Kenmore side by side not starting after defrost.
Just came back from a vacation and found all my food in the fridge spoiled, what a smell.
I have 9 years old Kenmore model 106. After cleaning all the smell first I tried to play with dial knob and nothing, than I tried to put knob to "OFF" and back to factory setting and it started working. After 2-3 hours it coolled pretty good and stoped, I have to manually turn the dial to "OFF" and than on again, it worked again for a while.
Now it seems always wants me manually to turn it "OFF/ON" after probably defrost.
I read some probems on the board and it sound like a relay problem.
Could someone please to confirm it or give me some suggestions to what and how to fix?
Thanks a lot.
  • PeterCh Dec 17, 2008
    I cannot tell exact temperture in the fridge, but what ever I have in the frizer now is frozen as usual and it seems it keeps the temperature fine as long as I keep turning it manually "off/on" every couple hours.
    How can I start debugging the problem? And can I do it myself or should I call SEARS repair service?
    Does it worth to repair if I can by a similar "Whipool" fridge for $700+ now?
  • PeterCh Dec 28, 2008
    Thanks for the experts advise, I ordered for $75 and installed new thermostat assembly and it works like new.
    Sergeant:
  • 409 Answers
Sounds like you may have a defrost thermostat problem, which is what makes the fridge cool. can you tell what the temperature in the fridge is?
Posted on Dec 17, 2008
  • Carmen Mikulic Dec 18, 2008
    since the problem is persistent, i would definitely think about replacing it. for the price and piece of mind, it's worth having a reliable fridge.
  • Whirlpool Master
  • 8,220 Answers
Probably has a defective defrost control from what you are describing.
  • Dan Webster
    Dan Webster Dec 17, 2008
    If you have to turn it off and then on to get it going I would say you need to change the cold control and the defrost control.
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
I have an older side by side kenmore and the fridge wont go lower than 50.. I am afraid my food is going to spoil
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Kenmore 44393 Side by Side Refrigerator
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator stopped cooling
the problem is in your freezer !
open the back wall of your freezer and check if the fan working then if you see a big build up of ice. then its your heater unit or your heater thermostat. to check that it is the problem unplug the unit defrost the freezer coil with hair drier gently and when it done plug it again and see if your fridg get cool (1h or 2) then you know its the heater unit or the thermostat :(
911servicetoday .com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
My 2 month old Amana Refridgerator with Freezer on
If your sure about spoiled food. Spoiled lemons are one of the worst, and the machine has not been abused, it's a problem of the selling dealer. Fan motors have been known to create an odor when their windings start to burn. Plastic items that become detached from the interior cabinet and wind up laying on the defrost heater which gets very hot during defrost is another, however, I would demand a service call (free) since everything on it is under warranty. Make sure it's creating the odor when the tech shows up.
Oct 30, 2009 | Maytag MFD2561HE Bottom Freezer French...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Smoke from bottom of superba fridge
Dear customer,
Plz perform the following checks..
  • Remove spoiled food
  • Clean refrigerator interior with a solution of hot water and baking soda
  • Clean the door seals
  • Remove breaker strips and check for wet insulation
  • Please rate this,Thank u
    Dec 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Food gets spoiled too soon
    the problem is gas build up in your fridge
    use arm and hammer baking soda boxes for the fridge.
    that will help a lot
    Apr 30, 2008 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
    Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
    148 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
