Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner problems When I appempt to scan a document into a file an error messae comes on the printer screen.
  • Mike Peluso
    Mike Peluso May 11, 2010
    Please post the error message (Complete).
    Mike
    Genius:
  • 2,785 Answers
Plz try by reinstalling the scanner driver
Posted on Dec 17, 2008
I have Canon MX 310. It prints, sends fax and copies with no problem at all. But it does not scan. I push the scan button and it then shows a screen that is black or color scan. It then changes to...
Hi
I think you will need to run the cd installer again to install the scanner driver on your printer.
You can check if the driver of the scanner was successfully installed once you view on the Scanners & Cameras inside the Control Panel and see the image of your printer scanner. It means it is connected and ready to be used. If you can not see the icon of the printer scanner there, then, it could not be installed or the printer is attached to other pc in the network.
Remember to use the printer as scanner, it should be attached locally to the pc you are using. Pressing the Scan button in the printer will save the scanned documents in the computer as pdf files.
In order to save the documents as jpeg files, you must need to use the scan option on the Scanners & Cameras inside the Control Panel.
Hope it helps. Just post back if you still have questions.
Dec 21, 2010 | Canon PIXMA MX310 All-In-One Printer
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I dont know how to scan
HI, The easiest procedure to scan a document using your scanner is open Paintbrush that is installed with your operating system. Click on File Menu at the top left corner of your screen, then select "From Scanner or Camera". Once you have selected the option, you will be prompted for your scanner. Select the installed scanner and go on scanning the image/document placed on the glass bed of your scanner. Once the scanning has been completed, save the image file.
Cheers!
Mar 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
I can't scan a photo or document
If you want to scan open Microsoft Word and go to Insert -> Picture -> From scanner or camera.
You can do the same with Paint. Go to File->From scanner or camera.
Then you will select your scanner and scan your document or photo.
Feb 10, 2010 | HP DeskJet F380 All-In-One Printer
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
After the scan, the program cannot save the file.
Alright, Open the "paint " program from all program/accessories/paint".
click on the file and click on the option scanner and camera wizard after that you will get a option for "scan" please click on scan to make and change and once when scan get complete. click on file and click on the save as to save the document.
good luck.
Nov 13, 2009 | HP PSC 2355 All-In-One InkJet Printer
It is connected correctly, i need to know how to scann and save the document. it is an easy thing, i do not have a desk top short-cut to be able to scann documents and save to a file to print and attach to...
As long as your computer has been programmed for the printer with disc that came with the printer it is fairly easy. You load paper as if you were going to copy, then your screen should come up on your monitor that asks what you want to do. If not look at your printer screen and press scan. Then use arrows to forward to were you want the scan to go file, e-mail etc. This should solve your problem.
Jul 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Scanned copy cannot be saved
Try to downlaod the software from HP.com
May 02, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
