Question about Sony Handycam DCR-TRV525 Digital Camcorder
Sony HANDCAM CCD-TRV40 -- no tape eject
The "EJECT" button under the control lid is not working ... and I can not eject the tape. There is an "ARROW-UP" indicator flashing on the screen when I turn the camera "on" ... saying that I need to eject the tape -- possibly some moisture on the tape itself. Again, the problem is I can't actually eject the tape ... it there some manual override of the blue EJECT button?
  • markiv396 Jan 13, 2008
    Same problem getting the tape holder to eject.
hardrocko
  • 1476 Answers
SOURCE: troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
Posted on Jul 24, 2006
cpt100
  • 154 Answers
SOURCE: Moisture sensor on sony ccd-trv87
Moisture sensor is on the main circuit board and to replace the sensor you probably invest $100-200 for repair. It's the sensor or component surounding the sensor which gone bad. No other way around it. Good luck.
Posted on Mar 14, 2007
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Posted on Oct 21, 2008
  • 586 Answers
SOURCE: Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
Posted on May 22, 2009
SOURCE: Tape will not eject
I had the same problem and I switched to smaller tapes. I had been using the 120 minute tapes. It seemed like the tape would lock up after a short while with the larger tapes.
Posted on Jun 08, 2009
CCD-TRV32 won't eject tape
Its better if you get it serviced by an authorized service center,If its not in warranty then try for any local mechanic.If you try to manually open it there is a very possible chance of any kind of damage.
Jul 29, 2012 | Sony Handycam CCD-TRV32 8mm Analog...
My sony Handycam video 8 ccd-trv40 will no longer record any sound. The camera will play back older tapes and their audio and video. Any suggestions?
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 21, 2010 | Sony Handycam CCD-TRV40 Camcorder
Tape will not eject
Apr 05, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony Video camcorder CCD-TR350E Blue tape ejection button
Same has happened to me... did you solve your problem? JT
Mar 25, 2009 | Sony Video Cameras
Tape will not eject
a small spring (eject spring) is getting dam or missplace due to that you having the problem
Nov 11, 2008 | Sony Handycam CCD-TRV58 Camcorder
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
Handycam CCD-TRV68 control panel/tape door acting like it died.
In order to solve this problem please order the control switch block (control pad) pn: 147642411. If you need more info please advice.
Mar 28, 2007 | Sony Handycam CCD-TRV68 Camcorder
Sony Handycam DCR-TRV525 Digital Camcorder Logo
115 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
