GENUINE TOSHIBA TECRA A9 PTS52A-OEY03F LAPTOP can you please tell me what you think this laptop is like
bigbiggs
  • 326 Answers
SOURCE: Toshiba Tecra A7 Laptop-faulty vga port
No, most any pc repair shop could replace Ur port. The complexity of taling a laptop apart is usually detailed. I repair my own, but keep in mind there are many different size screws and small parts in a laptop. Sometimes the cost of having a laptop repaired is not worth getting a more updated laptop. This technology moves fast.
Posted on Jun 16, 2008
stif_NEC
  • 441 Answers
SOURCE: Video Controller for Tecra M2
download the drivers here
moz-screenshot.jpghttp://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=856523&moid=555698&BV_SessionID=@@@@0479891764.1177854602@@@@&BV_EngineID=cccfaddkklfiidjcgfkceghdgngdgnn.0&ct=DL
Posted on Sep 21, 2008
kornho
  • 781 Answers
SOURCE: The sound is not working
check the obvious first
1. is your volume all the way down?
2. check if your volume is muted: on the speaker icon on the system tray click and check your volume is up and it's not muted
3. after checking 2. right click the speker and go into volume control, check your master volume and other items that may have the volume all the way down or muted and correct that and test
4 after checking 1, 2, 3 dlipbadgi suggestion is good: check you have drivers properly installed and your sound adapter is working properly. check sounds in the control pannel or check on device manager by going start>run >type devmgmt.msc then press enter.. check under sounds and check if you have a yellow "!" (drivers may not properly installed or adapter is misconfigured) or a "?" which could mean drivers are not installed. the go to toshiba website and with your model number look for the appropiate drivers for your pc and operating system.
Posted on Sep 30, 2008
bindudhindsa
  • 67 Answers
SOURCE: how can i goto setup
If you wanna go to BIOS setup it should be F1 or delete. PLease read the messages at startup. It should tell you which key you need to press for setup. But all BIOS dont have ACPI settings.
Hope it helps !!
Good luck !!
Posted on Oct 01, 2008
  • 28 Answers
SOURCE: I need to have the
DDR2 667, Expandable to 4GB,
Posted on Dec 19, 2008
RESET POWER ON PASSWORD
The BIOS pwd last time I checked could not be reset. You would have to contact the Toshiba Support and they may have another work around for the BIOS password. This is used commonly as an anti theft measure.
Dec 20, 2013 | Toshiba Tecra A9-S9012X Notebook
Toshiba Tecra A9 Model: PTS52A-0EW03F. Can i upgrade the graphics card, if i want to install dedicated card there is option or not. I also want to upgrade hard disk and Ram please advise me i can upgrade...
Laptops have built-in graphics card on the motherboard and cannot be replaced with a different graphic card.
You can upgrade the RAM to 4 Gb and install a larger SATA hard drive.
This WEB site gives the specs of this laptop.
http://www.cnet.com/laptops/toshiba-tecra-a9-s9021v/4507-3121_7-32906197.html
Dec 26, 2012 | Toshiba Tecra A9 Notebook
ARE ALL TOSHIBA TECRA A9 MOTHER BOARD COMPATIBLE AND I NEED A MOTHER BOARD FOR TOSHIBA TECRA A9 MODEL NO. PTS52E-012033ZA
Just buy another PTS52E it will be ok, but replacing a MoBo in a laptop means taking the whole thing to bits, if you dont know what your doing, let a shop do it for you.
Jul 09, 2012 | Toshiba Satellite P105-S6197 Laptop
Toshiba a9 in crisis as fatal mistake made! Tears shed.
You have no real problem. Just reboot your laptop and let it boot up all the way, then Press and Hold the CTRL+ALT+DEL keys and launch the Task Manager. When the task manager opens click the Processes tab, then click on the columnar heading Image Name to sort the processes in alphabetical order. Look down under the Image Name column and see if you see explorer.exe. If you do, click it once to highlight it then click End Process at the bottom of the window on the right side.
Click File at the top of the window on the left side, then select New (Task Run...). The Create New Task window will open up. Type: explorer.exe and click OK. Your desktop items will start reappearing.
Jun 03, 2012 | Toshiba Tecra A9 Notebook
I NED REMOVE BIOS PASWORD IN MAIN TOSHIBA TECRA A9
first you can remove lap top battery and cmos battery and keep your laptop 24 hours after you can reinsert your bios battery and main battery after switch on it. if still having the same issue?? " You call tech support. give PROOF OF OWNERSHIP. You then tell them your service tag/serial number, they enter it in a equation which parses the number and tey will give you a one time use password "
Sep 16, 2011 | Toshiba Tecra A9-S9013 Notebook
How do I change the RAM in my Tecra A9 laptop
you need to unscrew a screw from it´s bottom. The memory is pretty good accessible.
http://www.notebookcheck.net/Toshiba-Tecra-A9.5643.0.html#
Vladimir
Oct 15, 2009 | Toshiba Tecra A9-S9021V Notebook
Toshiba laptop shuts off immediately after it is turned on
Sounds like a power issue, there are a few things that can cause this:
  1. If you are on battery power, your battery is dead, either it's out of juice or the batter can no longer hold a charge. Solution here is to get a new battery
  2. The power adapter is not connecting to the laptop properly and the battery is dead. Solution here would either by a new charger, or if the connector on the laptop is bad, new motherboard.
  3. There is a problem with the motherboard. Solution here is a new motherboard.
Mar 12, 2009 | Toshiba Tecra A9-S9013 Notebook
Driver dc
Select your model on one of the web pages below depending on your location:
Toshiba Support - Homepage
Toshiba - Download drivers
Feb 16, 2009 | Toshiba Tecra A9-S9013 Notebook
I need drivers for tecra A9 laptop
got to the toshiba website & download the drivers you need
Jan 16, 2009 | Toshiba Tecra A9-S9012X Notebook
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
