Question about Toshiba 43H71 43" Rear Projection Television
RE: red green shadows
Hey thanks for the help but I don't have any idea where the purity knobs are located. Is there somewhere on the internet I can get all the info I need preferably free of charge? I really appreciate your help, Thanks!!!
    President:
  • 3,130 Answers
This is a projection TV, what do you mean purity knobs. What is the problem with your TV set? Sounds like you got some wrong info here? I will be on live tonight if you want to discuss your TV problem.
Posted on Mar 25, 2007
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Red, Green, and Blue shadowed lights
the lense red blue green is warped you will need to replace those lenses
Aug 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Jul 17, 2009 | Culligan Under Sink Water Filter
REDENT PURCHASE OF TV'S Have green in some spots.
This is typically referred to as a color purity problem and can be caused by two main things. The first cause can be stray magnetic fields which can 'magnetize' the TV screen either by something magnetic begint oo close to the screen or having turned the direction of the TV while it is turned on. If this is a purity issue caused by magnetic fields, it can usually be cirrected by powering off the TV for about 1/2 hour and turning it back on. All tube TVs have build in 'degaussing' circuits to cure just this issue.
If this doesn't fix it the other cause is a shifted shadow mask inside the picture tube itself and cannot be corrected.
May 25, 2009 | Televison & Video
Red colors have turned green
You most likely have lost red lamp function. This can be caused by a number of issues. None are going to be an easy fix. You can isolate the problem quickly if you are a tech, by doing a red/green gun driver board swap. Pretty much the only thing you can try to do yourself, is take the front panel off the TV, then adjust the color bias knobs usually located somewhere behind the panel. One will control the red, one for blue, and one for green. Mark them before you play with them, so you can return them to the factory settings if needed.
Nov 13, 2008 | Televison & Video
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Mar 24, 2007 | Toshiba 43H71 43" Rear Projection...
Picture background is Red Sony KP-57wv700
Is it a reddish tint or the picture is just red? Did it just happened, or you are just noticing a gradual change? Reddish tint: Blue and/or green CRTs are getting weaker. More likely the green CRT. Unplug the unit and somehow remove the back cover, etc. to get a direct view of the CRTs. Use a flashlight to inspect each CRT through its lens. CRTs with excessive wear will show a definite "burn" mark where the picture forms. Compare the center CRT (green) with the other ones. Normal wear in all three tubes is expected. What is important is to notice the difference. A significant wear in one means it has to be replaced, but usually all three have to be replaced in order to get the right purity. This is a major overhaul, and unless the TV has a sentimental value, it's not worth it. Picture just red: Green and blue CRTs not firing. This is easily observed by running the TV with the back cover removed. Probably a loose connection, but you will need the manual to trace it. You could gently tap the chassis while the TV is running and see if this restores the blue and green CRTs.
Sep 28, 2006 | Sony KP-57WV700 57" Rear Projection HDTV
Toshiba 43H71 43" Rear Projection Television Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
