Question about Kenmore Elite 21086
Our washer won't agitate nor will it spin properly what's the problem I have a kenmore washer and it is doing the same thing. How do you get the front off of the washer?
  • Kenmore Master
  • 8,220 Answers
It has a bad lid switch, a loose lid, or a broken lid strike.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Posted on Dec 17, 2008
  • 36 Answers
Dear Customer
please perform the following checks
Please rate this,Thank u
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Posted on Dec 30, 2008
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Washing Machines Logo
88 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
