Question about Kenmore 98702 Stacked Washer/Dryer
PLASTIC SECTION BROKE-
KENMORE STACKABLE 41789690110 W72044145. DRYER- IN FRONT OF THE DRUM- 2 PLASTIC SECTIONS. ONE OF THEM BROKE. HAVE NUMBER ON SECTION THAT ISNT BROKE- BUT NOT FOR ONE I NEED REPLACED. THE NUMBER IS136948. THANK YOU
  • 113 Answers
I know this image may be hard too see. If you can give me th number on the diagram of the part , I can get you a part #. The part# 136948, isnt a valid part #, hope this helps, Dave www.washermd.com
Posted on Dec 17, 2008
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
I have a stackable FEx831CSO. The plastic ring that goes around the dryer drum and holds it in place, broke and fell off. The dryer now makes a terrible sound and the drum is slamming around inside. Can...
It can be replaced. Here's a link to your manual for the dryer, which on the 2nd and 3rd pages has a diagram of it and a part number for you...when you have your part number you can order it either directly from Electrolux or find one on Ebay or another online source....if you have a local appliance shop you may be able to get one there as well....here's the link:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995396412.pdf
Nov 04, 2012 | Frigidaire FEX831CS Top Load Stacked...
Plastic bag (biodegradable) melted in dryer. Kenmore stackable HE2DHZN-ELE/2406024EL54 serial# MU4001347 Is it a porcelain drum ? Then I could wipe it with goo-gone? CT
most are sprayed on coatings,, try chipping off what you can, then use a heat gun if you have one to soften the bag for final removal,
Jun 30, 2011 | Kenmore Dryers
I have a stackable kenmore washer dryer heavy duty extra large capacity 2 speed motor. The dryer has been making squeeling noise and has stopped toumbling around what can the problem be.
Could be the belt which connects motor and dryer drum. Could be the drum support rollers. Replace both either way -- common problem.
Jun 03, 2011 | Kenmore Dryers
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer and dryer. The washing machine tub is tilted to one side.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore Stackable washer dryer. Dryer is not heating up. I need to find how to replace the element
The element is behind the drum. You have to remove the front panal and pull the drum out.
Eric
Jun 10, 2009 | Kenmore Dryers
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Balancing problem Frigidaire stackable front load washer/dryer
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
