Question about Fisher Paykel EcoSmart GWL15
Problem draining &spinning
Model#gwl15 when my washer get to the rinse cycle it seem to not drain the water nor goes to the spin cycle,I unclog the drain and it seem like this worked but when I started this time I started it on the rinse to see if it worked and it stay on the rinse for about 10m until it started to beep.
  • Pupsta Dec 17, 2008
    I have the same problem with my MW511. It seems there is a drum positioning sensor located in the magnet section of the motor. This can become corroded and cause the problems you are having. Have been told it costs about $A60:00 to replace. When I have done mine, I will let you know if it helps.
  • Fisher Master
  • 8,220 Answers
Get the strings coins and sand out the pump and retry
Posted on Dec 17, 2008
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Why won't my 4GLTF2940FS front load washer will not spin. It will go though a wash cycle, but when it is time to drain/spin the load it immediatley goes to No Spin, then shuts down. The water drains
Hello friend, I appreciate your post!
Based off the information you have provided if your Frigidaire washer is draining and rinsing but not spinning it could be an issue with your timer or motor. I would reset your appliance by disconnecting power to it by unplugging it or flipping the household circuit breaker for ten minutes. If that does not work I would recommend having a technician out to the home to properly diagnose and repair the appliance, since it could be any one of these underlying issues. Hope this helps. -Matt
Jul 28, 2014 | Frigidaire GLTF2940FS 3.5 Cu. Ft. Front...
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Washer won't go past the wash cycle
YES !! check out the DRAIN MOTOR PUMP it could be clogged , AJ
Dec 18, 2009 | Fisher Paykel EcoSmart GWL15
My f&p is not draining or spinning
You have a broken lid switch that needs to be replaced. The washer thinks the lid is open. A model # would be helpful. thanks dave www.washermd.com
Dec 16, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
484 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
