Question about Dryers
Dryer wont dry!!
Its an old school maytag dryer has no serial # but also has no heating elements!!
  • Dryers Master
  • 8,220 Answers
That is one of them fluff condensers. You hang out the clothes on the line outside and then bring them in to be fluffed. I am pretty sure.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 17, 2008
Maytag atlantis dryer wont shut off. changed the timer and it still wont move.
send the model number.if this is electric try this.put it on air fluff and start it,if it has heat your element is bad,it's grounding out,part of the element is touching the metal case around the element.if it just did this on auto i would say change the cycling thermostat but on timed dry it just counts down like a clock.i saw this once and the element was bad,grounding out.it was tricky i thought it was the timer also.
Nov 27, 2017 | Maytag Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
I have an old Maytag dryer and its model # is LDE8800 and the serial # is 201878 DU and there is no heat in the dryer cycle anymore. It runs but doesn't dry anything--any help? thanks! Ali
Need a new heating element. had a look around cant find one for yours, maytag did recall a lot of heating elements due to severe problems. they are not a very good brand. i think the model is too old for a new element. Time for a new dryer i think. try Hotpoint or LG
Dec 01, 2010 | Maytag Dryers
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Whirlpool dryer model #le86200pq1...does not heat up anymore so does not dry clothers. Cannot seem to find manual. Any downloads available for this model.
Old School Dryer Nice one. 9b580b7.jpgprobably the element. Take the dust cover off the back1bc83b1.jpg and check the compents. It ain't always the element if you have blockage then them fuses blow. 1= limit blows when the vent is clogged3aca83a.jpgCheck these area also24a7597.jpgYour OLD SCHOOL SERVICE MANUAL MATE!
May 11, 2010 | Whirlpool Dryers
Heating element out, dryers runs
replace element but clothes still wont dry helpppppppppppppppp
Apr 21, 2010 | Maytag HYE3657A Electric Dryer
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
Marvin
Marvin
