My wall heater fan keeps going on and off without any adjustment to the thermostat???When I turn if off at the thermostat, it takes several minutes to stop doing that.
  • 405 Answers
Honestly they or designed to run till the temp inside has cooled down. This is normal. I hope this helps.
Posted on Dec 17, 2008
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Dec 06, 2017 | Cozy Heating & Cooling
Why is it that when I switch off the heater the fan stops instead of the fan keeping going for a couple of minutes like it use too it now turns off at the same time can anyone help?
Did you replace the thermostat? The feature may need to be programmed into the thermostat.
Some heaters have a sensor, a time delay, this sensor is a temperature sensor wired in the blower motor control circuit, the sensor senses space by the heat exchanger.
When this sensor is sensing hot, it activates the fan and when the sensor does not sense hot, it deactivates the fan. The sensor seems to not be controling the fan anymore but the thermostat is.
Jan 06, 2015 | Heating & Cooling
Cooling fan will not shut off
You may want to replace your thermostat. It sounds like it's stuck open. Someone suggested that I remove the positive wire from the battery terminal for about 10 to 15 minutes. This corrected my problem.
Dec 05, 2011 | 2005 Chevrolet Impala
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
With my thermostat on auto and on heat, and the furnace turns on, the fan will not turn on with it. If I switch the fan to on it will run after I repeat back and forth from auto to fan on several times...
Well, here is the deal: unless you rewired from two wire to multiple (usually 4 to 10 wires) wires, the fan cannot be controlled from the thermostat, even though the thermostat indicates that it can > it is a physical wiring and fan administration issue.
Unless you have a newer furnace, the fan is controlled by plenum temp. Works like this: burner turns on, no fan until the plenum temp reaches set temp,....then burner off, and fan keeps running until pelnum temp drops, and often the fan may kick on a few more times as this temp depletes.
Oct 03, 2010 | Honeywell Electronic Programmable...
Frost on wall
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods Freezers
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be...
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
Jul 16, 2010 | Amana Refrigerators
The fan runs whether the thermostat is turned on or off. If the thermostat is on, the burners fire up. The only way to get the fan to stop is to inplug the furnace.
Chances are you ahve a bad fan limit switch. If it is adjustable try to adjust. Set at 90 and 120. If it is off a little move the temp up a little. Should have slide dial under the lid on the fan limit. Keep in touch Rus
Nov 25, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Fan keeps running.
Some programmable thermostats have a circulate feature. This feature will allow your fan to run approx. 20 minutes per hour. This will insure better circulation, a better balanced temperature throughout the home & better air quality do to more air filtration. Read your thermostat manual to see if your thermostat has this feature and how to turn it off if needed. Another possibility would be on an older furnace with a fan limit control. If the temperature settings are set to low on the fan limit (or if the control is malfunctioning) you could experience a fan that runs a lot even if the thermostat is off.
Apr 10, 2009 | Honeywell Electronic Programmable...
Rinnai fan stops turning.
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Aug 13, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
