Question about SanDisk Sansa e250 MP3 Player
Turn on puhleezee!
When i want 2 charge my mp3 it comes up saying the battery is 2 low. What am i supposed 2 do?????????? i need 2 charge it!!!
  • 2 more comments
  • wyattsmoma Nov 06, 2007
    Seems alot of us are having this Issue... I personally have replaced both Battery Chord and Switched Computers... Nothing helps... If anyone has any true Suggestions theyr'e welcomed!
  • gracie strawhorn Feb 07, 2008
    i finally figured it out=) you have to plug in the charger, and then the sansa turns on. then, it starts to charge. hope this can help anybody who needs it!
    i figured it out.. thankss.
  • judy6213 May 11, 2010
    PHILIPS GOGEAR HDD1630 not charging. Not enough charge for it to be reconized. Does anyone know how to change the battery in this unit?
  • 43 Answers
You need to change this battery >> this is only solution for this,,, good luck
Posted on Apr 27, 2007
How long have you had it for? If you had it long enough, then your ion battery is done for and has no more energy.
SOURCE:
SanDisk Sansa Express 2 GB MP3 Player (Black), battery status states 14% critically low....what does it mean and what actions should I suppose to do?
You need to charge the battery so you can continue playing your MP3player.
Connect the supplied USB cable into the player and then plug it into the USB port of your computer. The computer will charge up the MP3 player and you can also copy mp3 music and photos etc to the MP3 player.
Aug 25, 2011 | SanDisk Audio Players & Recorders
My sumsung YPK-3 mp3 player does not charge. When I connect to the PC the usual charging screen comes up saying it is connected and is charging. Even after over 5 hours, it did not charge at all and when...
The battery is at fault. The charging circuit is fine as it says CHARGING. As the battery is at fault you may like to as Samsung to replace it if the device is still under warranty. Else replace the battery.
Jul 05, 2011 | Samsung YP-K3 MP3 Player
Will not charge--will come on plugged into pc tower,but will not charge
it's charging when plugged into your pc, if it doesn't hold power well you may have a defective battery, plug it in and let it sit for 6-7 hours and see how long the battery holds out. if it doesn't work you have a bad battery.
Feb 15, 2011 | Sony Walkman NWZ-S616F MP3 Player
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
What's wrong?
i suppose your batteries are busted. try replacing them
Jun 07, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
Apr 18, 2009 | SanDisk Sansa Clip MP3 Player
All it says is low battery
USB cable should come supplied - call RCA
Mar 28, 2008 | RCA OPAL M4001 MP3 Player
All it says is low battery and charging
The battery life is short - you must recharge every day
All it says is charging and low battery charging
Must recharge every day by replugging into your computer
C200 dont charge
Try changing the battery.
Dec 16, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
