Question about LG (LRBC22522ST) Stainless Steel
Fan begins to make noise - then fridge stops.
Below is a posting from a few days ago about a fan problem that is causing my LG fridge to stop cooling. Wiz offered some ideas, most of which I answered below, and I never heard from him again.
From what I can tell there is ice build up behind the freezer wall causing the fan to stop working. I don't know how to get behind the back wall and if I need to take the ice maker off in the process. The wall near the ice maker is pushing forward more than the other side indicating ice build up near the ice maker. Maybe a leak.
Any ideas?
LG Model lrbc22522st:
After noise starts I defrost the back wall of freezer with warm water and or hair dryer. But within weeks the noise returns. I read on your site (I think) about cutting away some insulation to give the fan more room but I don't know how to get to the fan. I was unclear how to remove the back wall of the freezer and if I had to also remove the icemaker as well.
Could there be a leak of some kind behind the freezer wall causing ice buildup and fan interuption?
Any help would be appreciated.
-Phil
Hello and thanks for the suggestions.
· Hissing and popping is normal on frost free refrigerators, it is the defrost heater
The noise is not hissing or popping. It sounds like a fan blade hitting something. It only makes the sound when the circulating fan is on.
· Check that the refrigerator is level
Fridge is level.
· Check the drain pan
Drain pan is fine.
· Check the condensor fan
I cleaned the condensor fan and it works fine.
· Check the evaporator fan
I think the evaporator fan is the fan I was referring to. Is it the fan that circulates cold air into the refrigerator compartment from the freezer? If so, that is the fan that can get encumbered by ice and icy insulation preventing cold air from getting into the refrigerator compartment. So cutting away the insulation would be a solution. Is this the same fan?
· Inspect the compressor mounts
I will inspect these this evening.
  • Taka Iguchi Jan 16, 2009
    Mine is doing the same thing.  I'm defrosting it overnight and cutting away the foam a little bit to see if that helps.  Anything else I should do?
    Sniper:
  • 66 Answers
Since this issue is repeating on various models, I point you here to a manual (with images) that explains how to fix this frozen fan / drain pipe. Here is the manual by Avi Remember, manual 24h defrost is the easiest thing to do b4 you take more actions. good luck Avi
Posted on Jan 29, 2011
    Novelist:
  • 161 Answers
You have a defrost system failure and needs to be checked.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hairdryer to warm the back wall, 20-30 min, put everything back, turn it back on and you should be good for a couple of days.
Posted on Dec 17, 2008
2 Suggested Answers
Fixe_You
  • 1800 Answers
SOURCE: Fan begins to make noise - then fridge stops cooling
HI.
plz do rate this post so i can help others.
Good Luck.
Posted on Dec 15, 2008
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Whirlpool side by side fridge stops cooling/freezing!!!
No its not button I would know about after 30 some years. You may be having 2 or more symptoms begin caused by the same problem though. The noise at night tapping may be because (and indeed may be doing it ll the time you just don't notice it due to the angle of echo in your home and kitchen) I suspect the fan blade (Im betting on the one behind and below by the compressor) is either bent slightly or hitting. something. I have seen anythign from mice to papers get close to the fan blades and cause a mistery problem. This would explain the defrosting also especially if it cant get going again.
Take off the back cover and look for the fan motor and spin the fan if its stopped. You also need a strong flashlight to look out for what might be causing it. If it is a mouse dont worry he will only be bothering those cats that have lived into the 10th life.
As for the grinding noise.../when you get water... and the leaking... is the leaking comming form the water area or the defrosting? Ok you say defrosting so that could be explained by the outer fan. The noise though maybe even the cardboard baffel in the back is getting in the way of thatfan in back. And i think it might be your water line gettign hit by this fan. That would tie in and make all the trouble stem from a water line hitting the fan. If tihs is it please tell me so I can recover from not knowing if Im helping people out here. Im beginning to think Im wasting my time. Please post more so I'll know.
And if you tell me, please rate me too
Mar 15, 2009 | Whirlpool ED2FHEXN Side by Side...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
HI.
Good Luck.
Dec 15, 2008 | LG (LRBC22522ST) Stainless Steel
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
LG (LRBC22522ST) Stainless Steel Logo
387 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
