Question about Brother IntelliFAX 2800 Laser Fax
Copied pages are all black
When I try to copy a page on my Brothers Intelifax 2800, the copied page comes out almost all black so the copy can't be read. I there a part that I can replace to fix this problem or is the machine junk?
  • 328 Answers
Is is a lower end product for light duty use. You can try a new genuine OEM drum and or toner, but buying them both would cost as much as a new 2800. Can you print a internal report OK?If so, then your scanner is defective. A common problem with 2800,s
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 07, 2007
SOURCE:
A copied page comes out all black this is using all my ink i can print a test page or from a file but a copy is black
hi anne lift the lid just alittle press the copy button and see if the scan lamp lightes up, if not u may need a new lamp, good luck geodaws
Dec 09, 2013 | HP Photosmart C3150 Printer
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Printer doesn't copy
indicates that the page on the scanner is upside down
the printed side faces down
Oct 26, 2017 | HP Photosmart C4180 All-In-One InkJet...
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Black steak on copied paper
Clean the scanner glasses, check the little glass, if it have scratches. There is a white strip across between the 2 glasses, be shure to clean it up.
Oct 23, 2008 | HP LaserJet 2840 All-In-One Printer
Hp business inkjet 2800
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
Jun 20, 2008 | HP Business InkJet 2800 Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Brother IntelliFAX 2800 Laser Fax Logo
350 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
