Question about Microsoft Xbox 360 Console
I have 2 left red lights
Hi, I did the xclamp replacement thingy and now when i turn it on immediately it has the 2 overheat lights on. do you have any solutions?
    Scholar:
  • 31 Answers
I suggest you to try DIY Guide that wil explain solving the 2 red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Posted on Feb 20, 2009
2 and 3 red rings
The 2 red rings error is an overheat problem. Something you did when you attempted the previous repair has prevented the 360 from cooling properly. I suggest having a professional examine your machine.
Jan 21, 2010 | Microsoft Xbox 360™ Pro White Console
Keep getting same thing over and over??
u r going 2 need 2 open it up take the xclamps off so u can get at the CPU and the GPU chips , u will need silicon gel 4 both chips , 1 red light is just the same as 3 red lights its due 2 over heating of both these chips, i had the same problom and after i put the gel on the chips it works fine now, go 2 u tube 4 a video on how 2 take the xclamps off.
Jan 13, 2010 | Microsoft Xbox 360 Console
Error Code 0020
First, my xbox would have one red light and E 74. Then when I opened it up and booted it I got three red lights and 0020. I took out the motherboard, replaced the heatsink compound and did the x-clamp fix, but I couldn't get nylon washers in the right size so i just used no washers at all. Varying the tightness of various x-clamp bolts gave me 0020, 0003, 0002, 0001, or it would boot up to the black screen and I'd get E 74 again. Other times the xbox would almost immediately overheat. Most of the time I would get 0020, though. At that point, I gave up and I just tightened up the bolts replacing the x-clamp a certain way (nothing seemed special about it) and put the motherboard back in the case without testing it. I screwed everything back together, and since the heads of the bolts were thicker than they should have been, the motherboard didn't really sit flat in the metal cage. But i just screwed the motherboard back into the cage not to tight with the 9 small silver screws, which I would imagine put some stress on the mobo. Then I pu the rest of the case on and the 6 long screws, and once I had snapped everything back together I tried booting it up. To my great surprise it booted up fine! I played some halo 3 and it has booted up fine every time (3 times) since then
Many people have got this error You need to replace the xclamp and make sure there's extra pressure (less than half a turn) on the front right corner of the GPU. You can read more about xclamp replacement here.
its not an issue with ur HDD so no worries....
regards iversh
a very helpful rating is appreciated for answering ur query
Sep 17, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Xbox360 has 3 red lights
Its when the solder overheats and disconnects a wire in the xbox. If you have bought it within the last year, you can return or swap for new wherever you bought it. If not you will most likely have to send it off to xbox repairs.
Apr 01, 2009 | Microsoft Xbox 360 Console
2 red rings after the xclamp fix
Yesh...4 red lights means you didn't have the component or hdmi pluged into the system and tv. 3 lights means there is some soldering problem in your 360. 2 lights means your 360 is overheated. For the 2 lights normally you can fix that with letting it cool for a while and give it some room around the system to run cooler. However by using the towel trick you you caused the soldering to run and now it's probibly miss soldered. I recommend you ship to Microsoft or sell it.
Mar 22, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 xclamp fix done now it boots but no power
So, you Red Ring fixed your 360 and now your trying to overheat it and there's no power to the Xbox? I want to make sure I understand your problem correctly.
Nov 22, 2008 | Microsoft Xbox 360 Console
RED Ring of death xclamp fixed but..
Do you have the fan in? If you do, take it out or put 2 screwdrivers through the back holes to stop the fans from spinning. IF you have the fans out and its still not overheating, just leave it on for a while until it does. It will overheat eventually.
Xbox 360 0020 error code
here is a site i found that shows detailed fixes for this error with your 360's - here it is
Jan 05, 2008 | Microsoft Xbox 360 Console
2 red lights after x clamp replacement
It means basically that the xbox is starting tio overheat fast. what sometimes happens is those x-clamps have to be tightened in a sequence and tight as possible but not too tight to crack the board or cut the small PCB traces. Open up the console again and just have a look underneeh the motherboard make sure there are no torn green pcb traces ( put simply green lines that connect to a silver blob of solder ) and make sure the screws are tight enough.
Dec 11, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
