Question about Pacific International Federal Pacific Breaker
Subpanel I am installing the subpanel a distance away from the main panel. After I run the heavier wire from the main to the sub I will need to run the existing wiring from the main panel to the subpanel. What is the best way to accomplish this?
    Sergeant:
  • 359 Answers
The only way unless the existing wiring is long enough or can be re-routed to the new sub is to use junction boxes with covers and wire nut to connect the wires ( make sure that the wire is the same as the wire you are connecting to and install breakers to accommodate the amperage rating of the wire examples are # 12-20 amp, #14-15 amps , # 10-30 amps # 6 50 amps do not put any 220 volt and 120 volt in the same junction box and no low voltage wire in with 120 or 220 volt wires , if you will need to splice the range wire or any wire larger than #10 i would recommend replacing with new wire if this is not possible then use only connectors approved for the wire to be used .good wiring !
Posted on Dec 24, 2008
Electical panel
1) Add a subpanel using extra breaker space:
http://waterheatertimer.org/How-to-install-a-subpanel.html
2) Choose correct wire and breaker.
Increase to next larger size for distances over 100 feet from breaker.
http://waterheatertimer.org/Color-codewire.html
3) Calculate total load on main breaker to make sure service panel is large enough for amp draw:
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
4) Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 11, 2013 | Electrical Supplies
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
I have a 200amp main with a 150amp sub panel and I'm not sure of the wire size I would need for an 80 foot run. With the multiple answers I got confused. I was told 2/3 w/ground, 2/0, 2awg or #2. Also, I...
All of the answers you got were all for the same product, it's just being said differently. 2/0 is the correct wire size. I think this question may be old, so you may have already completed your project. By the way, with copper, the voltage drop on an 80 ' run is 0.8 %. On aluminum it is 1.56%.
At any rate, a 150 amp sub-panel with 20 circuits running on a 200 main amp can easily be overloaded. You should probably have a 300 or 400 amp main with a subpanel that large.
May 13, 2009 | Electrical Supplies
Subpanel feeder
Run 1 1/2" to 2" gray pvc conduit.
Mar 30, 2009 | Cooper Wiring Devices INC #BP4404V IVY...
Subpanel hookup
Yes the maximum size branch circuit breaker that will fit in a residential load center is 100 amps. I would recommend that you calculate the amount of power that you need the sub panel to handle, then add any additional loads you may need in the future. Hopefully this is less than 100 amps. I would recommend that you check with your local electrical inspector to make sure your installation meets all local and national codes before proceeding with the install.
Dec 31, 2008 | Your One Source Homeline Load Center, 200...
Subpanel wiring
You need to run the appropriate size wire from the main panel to the new sub panel. I would recommend getting a electrical contractor to do this for you.
Dec 16, 2008 | Pacific International Federal Pacific...
Pacific International Federal Pacific Breaker  Logo
768 people viewed this question
Top Pacific International Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a Pacific International Electrical Supply Expert? Answer questions, earn points and help others
