Question about Elite 2007 Shelby Gt 500 Ed White 1:18 Diecast Model
Disherwasher runs but doesn't spray water at all
I have Kenmore Elite dishwasher, about 3 yrs old, still pretty new. Out of the blue, the control panel stopped working, only the light of Quick Rinse key is flashing. I figured that the sensor keys were stuck; tried different way to make it unstuck. Don't know what I did but I could use the Drain option (OMG, the machine just began to stink from the back flow water from the sink). Fiddling more with the control panel, I got it to work, unfortunately only partly because dishwasher stops spraying water when in use. The machine operates as normal as usual just minus the water. What gives? Please help! Cannot afford a new one or a service call.
  • 158 Answers
SOURCE: some keyboard keys don't work
you don't say which keys don't work and if the keyboard is more than 1 year old you may open case via the screws in back of keyboard please note down the keys that don't work then the keys that you don't use that often just swap the rubber conntacts on them if yours has the rubber membrain it needs to be sent back to the manufacture of the keyboard to have them replace the membrain but if the keyboard is in warrenty then get it sent back with the details of sale. look for all screws they may be hidden.
Posted on Aug 14, 2007
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Posted on Jun 26, 2008
SOURCE: kenmore elite microwave is not
I unplugged the microwave for a few inutes, and let it reset itself. found solution on another site that DID NOT CHARGE ANYTHING for people to share solutions with each other!!!!!!!!!
Posted on Aug 03, 2008
  • 3 Answers
SOURCE: my elite operator will only close part way, seems
You will have to increase your force (sensitivity) settings on the p.c. board. Without knowing what type of board you have I can only guess. There should be a pod you can rotate with a screwdriver to increase the force. If it has an LCD readout with menus search the menus for force or obstruction, then increase it.
freddy51
Posted on Feb 08, 2010
ercupa190
  • 12223 Answers
SOURCE: My Treadmill is stuck on an incline and won't work.
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1) No signal from the console TIGHT flexible cable from key panel vs display board
2) the console failed tight the connector from display board vs lower board.
3) The motor failed from a worn belt and deck Test for 115 VAC without load..
4) Main Motor Board faulty Test for 115 VAC for input AND OUTPUT for +5 VDC.
5) potentiometer geared to the motor adjust it..
6) gearing can slip, giving the console false information .
See the block diagram that I did for better understanding. sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Posted on Dec 19, 2011
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Why does the heating element in my Kenmore elite look like it has a white film on it?
hard water. test water hardness, clean out with 8oz of CLR. and run affresh once a month for maint. ALWAYS RUN A FLUSH CYCLE AFTER ANY CHEMICAL
Oct 02, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore Elite Dishwasher not cleaning well
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
45jdgyhj
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Elite 2007 Shelby Gt 500  Ed White 1:18 Diecast Model Logo
Top Elite Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Elite Toy Expert? Answer questions, earn points and help others
