TX 51p100H Rear projection
We have a Panasonic CRT rear projection .
comes with faulty convergence STK IC, and i replaced both IC .
After that try to align the convergence but data lines are bent up and down, and when i align right side data on screen left side data moves. I've circuit diagrams of this TV and i found few 10ohm resisters burnt i replaced those resistors with same value.
finally i strongly belief the fault in micro processor of this convergence section unfortunately that spare is not available.
I'm back did you get any idea from my explanation..if yes please give me a feedback.
Regards,
Soman
SOURCE: samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Posted on Sep 25, 2007
  • 1779 Answers
SOURCE: Panasonic Rear Projection PT-47WX42CF42
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Posted on Apr 04, 2008
SOURCE: STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Posted on Mar 11, 2009
maatmartin7
  • 1244 Answers
SOURCE: convergence prob on toshiba mod 57h82...is stk
No. If you already tried, you already know why. Repair on TVs require the exact parts. If you feel you can repair this, the suggestion is see the website,www.TvRepairKits.com. Here they can instruct very throughly. You will find photos to see what you will be working on. I have repaired several TVs using this web. Be sure you have the model number and the symptoms you describe. If you have any further questions concerning repair, ask me here. Thanks for asking and show a few hands of support.
Posted on Mar 10, 2011
  • 1030 Answers
SOURCE: Pico fuses were open on deflection pcb by Conv. IC
6 blinks is an indication of +5 volt over or undercurrent boltage. ussally on a or b boards
Posted on Mar 23, 2011
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Convergence IC's
Stk 394-160 are the better IC and they are available in the DP15H Upgrade kit at the following link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Panasonic PT-56TW53 56 in. Rear Projection Television- won't turn on -flashes 3 red lights- what's up? Turns on for a second, then it turns off and red light flashes 3 times... I've seen several other...
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part numberAA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Feb 16, 2018 | Panasonic PT-56TW53 56" Rear Projection...
HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Jul 13, 2008 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence issue
so you keep buying new tvs each 4yrs or so..all about money..
Jul 28, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Convergence adjustments
did you use the proper STK IC's Do the replacement IC's have SANYO on the face of them? If they do not, this could be your problem. You must use the IC that the manufacturer recommends. All IC's are not alike. Go to MCM electronics and enter your IC number and they sell original SANYO IC's. Good Luck
Jul 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
