Question about Toshiba CN36H97 TV
Toshiba cn36h97: no picture, only purple line in middle.
I have Toshiba cn36h97 that will come on with no picture, only a purple line in middle that will go up and then the screen goes blank. When it is powered off it will expand up from the middle to white rectangle and then off. Earlier it would sometimes work OK, but seems to take longer to come on than normal.
Thank you very much for your help.
    Master:
  • Toshiba Master
  • 267 Answers
Hello!
Here is a link to the manual. Hopefully, it will help!
https://manualsbrain.com/en/manuals/1385674/?page=54
Posted on Sep 09, 2017
  • 308 Answers
SOURCE: toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Posted on Mar 12, 2007
premtech
  • 934 Answers
SOURCE: picture limited to a single pixel horizontal line, sound fine
This is actuall quite a simple problem... What you have explained here is a loss of vertical deflection. By the symptoms you described, working now and not working it's most likely the the vertical IC an LA7847-E has probably become ring-cracked at the point where the pins are soldered to the pc board. Depending on how long it has been allowed to arc the IC may have failed also, but they are not terribly expensive or difficult to repair - at least not here in the shop. The main board has to be removed. Locate the vertical IC - it will be mounted to a metal heat sink and the IC will be stamped LA7847. Then turn the board over and inspect where the pins are soldered to the foil side of the board. One or more will look ring cracked or fractured all the way around the pin. At this point you have two options, carefully reflow solder over each pin and put it back together or replace the IC by de-soldering it and removing it from it's heatsink. remember to use a good heat sink grease when applying the new IC.. There should also be a couple of caps in pretty close proximity to that IC... One should be about 50v/100uf and in the shop here we test em all... You might also just replace that one for good measure - they're not expensive either... If any of this sounds too complicated take it to a reputable shop and pick it up in a day or two.. Job shouldn't be that expensive or time consuming. My record in the shop here for doing those is 15 in one day. Average cost for that set, we charge is under $100 if you bring it in and pick it up.. Hope this helps Bill If you're calling around to the repair shops you might just ask if they have that IC on-hand or if they will need to order it..
Posted on Jun 07, 2007
Benimur
  • 6966 Answers
SOURCE: No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
fanicate
  • 60 Answers
SOURCE: toshiba 36" picture compressed to single line in middle of screen
there is a problem with vertical baleiage on your screen and need one ic changed but you cant do that yourself need to go in authorized service
Posted on Dec 10, 2008
SOURCE: Shrinking Picture
daniel719 was correct - my local TV repair guy fixed it for $65 and told me the TV would be good gor another 5 years easy - Yay!!
Posted on Jul 30, 2009
Where is location of remote sensor in tv
Has to be on front of set--either stand alone or mounted on a board where front controls are---
Nov 08, 2012 | Toshiba CN36H97 TV
I have a toshiba laptop with a built in web cam when ever i go to it, it only show up purple and green. How can I change the color so that I can see the real picture?
Hello there,
If that purple and green that is showing on your camera is the screen cover, then we can disable that. Go to camera settings/effects/disable the screen cover. If not then go to device manager/imaging device/and uninstall the chicony driver but do not delete, then restart the NB, then try to start the camera.
Hope it works.
Mar 12, 2011 | Toshiba Satellite P305D-S8828 Notebook PC
Picture is a flat line in the middle of the screen
Hello. Is the line is from left to right or top to bottom
Mar 01, 2011 | Toshiba CF35F50 TV
I have a Toshiba 32"
You need to replace the TV screen. It could not be repaired. Just get it replaced at dealer.
Regards
Dec 17, 2010 | Televison & Video
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
Toshiba CN36H97 TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
