Question about Sony PlayStation Portable (PSP) Console
How do i get past other peoples wep code?
Every time i get a signal, the user has wep security and i can't get past the password. can somone help me out
  • 8,197 Answers
Try this.
I would try 0000 first if that dont work then try this
I think you can reset it by going to settings > restore default settings. this will reset all your settings like date, time, nickname, etc.. and it should also reset your password too.
Posted on Dec 17, 2008
How do i find wep key
Connect your router to computer with lan cable then you can access it with default link http://192.168.1.1 then type user as "admin" and password as "admin" or blank or "password" then you can see settings of router. Click on wireless then wireless security WEP key note down the code it is your password to connect wireless. Let me know if you need further assistance. Thanks for using FixYa.
Apr 06, 2011 | D-Link DIR-615 Wireless Router
I cn not find my wep code
Hi bobraywhite,
Try to locate the wep code underneath the router. If you cant find it I suggest trying the following steps:
1. Use the Internet Explorer browser.
2. Type the following IP address in your address bar: 192.168.1.1 , you will get a login window. Your user name can be blank and the password is admin. If you have trouble logging in use the user name: admin, and the password is: password.
3. Click on "wireless" then "wireless settings" or "wireless security." Toward the bottom of the screen look for "Security Encryption (WEP) key," if you see more than one WEP key use the first one listed.
Hope it helps.
Bestregards,
Reyjoshua07
Jan 25, 2011 | Computers & Internet
How can i secure my signal on
Open a browser and type 192.168.1.1 into the address bar. This will link you directly to the router. A login and password screen should be displayed. The default user is admin with the password admin or a blank password depending on the release date. If you have changed this it will differ.
Once in the router menu, select the wireless tab and then the wireless security tab. This gives you options to secure. Select either wep or wpa and enter a passkey in which you want to use as you password. Write this down as it will be necessary to get on your network again.
Click save and connect once again to your network now using the wep or wpa code.
//halfs
Sep 02, 2010 | Linksys Wireless-G WRT54G Router
I have Belkin g wireless router modem but i don't have user manual that's why i can not puting the security password and so many people are using my modem, pls help and teach me how i put security password...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP and enter WEP code it is your password to connect wifi. Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Aug 15, 2010 | Belkin F5D7234-4 Router
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
I need to lock it so people cant get in with a password
http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 04, 2010 | Belkin Computers & Internet
I want the password to put the secure code
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
If you already set the code then if you can read it then you can ser it in wireless but if it is in 8 or # format then add new wep code .
Jun 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Want to know how to put a security lock on my router so people can stop stealing my service ?
http://192.168.0.1
or
http://192.168.1.1
Apr 29, 2010 | Linksys Wireless-G Broadband Router
Help me secure my router. D-Link wbr 1310
http://192.168.0.1
or
http://192.168.1.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Dec 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do i unlock my belkin45g because i locked it to stop people using my connection but now i cant use it myself
For that you need to connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.15.1
type user name ads "admin" and if it ask for password then type "admin" or blank or 'password"
If you can't access it then you have to reset it.
press RESET button for 10 seconds it in back side of router.
Then followthe above procedure.
Then you can see configuration page.
Go to wireless then security.
Set your wep code new or write down wep code then save settings and exit.
WEP code is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | Computers & Internet
Sony PlayStation Portable (PSP) Console Logo
117 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
