Question about HP OfficeJet 6110 All-In-One InkJet Printer
My hp office jet 6110 all in one will not allow my hp pavilion dv 5000 to initiate a scan from the "director". I have reinstalled the drivers that came with the printer several times and of course restarted my laptop several times (both with the printer on and off). Any Ideas?
  • greggcowley Dec 17, 2008
    Thanks for your speedy reply MIke. I am sorry I was not more clear, the DV5000 is the model number of my HP pavilion laptop that is connected to the hp office jet priter. the 6110 officejet is selected as my default printer.
    The printing functonality works great. It is just the scanning that is having issues.
    Thanks
    --Gregg
    President:
  • 2,351 Answers
Hi greggcowley, having two HP's connected or bouncing between either you need to change the default printer before using either. Open printer and faxes. You'll see only one device has a check mark on it. So before you go to use the 6110 left click on it once, than click File & set to default printer. Same for the DV 5000. Each time you'll need to open printer & faxes & change the default printer/scanner.
Enjoy greggcowley!
Thank you for using fixya.
Merry Xmass!
Mike
Posted on Dec 17, 2008
  • Mike Peluso
    Mike Peluso Dec 17, 2008
    Hello again greggcowley, I messed up my answer above. Noticed you gave more information in a second post of your's.
    http://www.fixya.com/support/t1391525-hp...
    Forget my other answer.
    I have come across this issue before. You can call HP all day long & it will not help. You can uninstall & reinstall & it will not help.
    When windows was installed it failed to install some basic HP files within system32 folder. I had no choice but to install windows again. (Scanner failed to function) HP 5500 series.
    Once windows was re-installed the printer functioned just fine including the scanner. That is the difference between your Pavilion DV 5000 & the Dell OS. Back up your data & reinstall the OS (Fresh preferred). I'am 100% sure this will work.
    It worked for me.
    Merry Xmass!
    Again Mike
    Mike
Hp office jet 6100.
is ther firmware update to it go to www.hp.com suport area download latest drivers ok save to hardrive then remove old ones then install new ones from add remove in control panel ok after new driver hold power in unplug it then plug back in hold that power for 10 sec manaual reset also in the settings
Jan 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Office Jet 7210 Scanner won't work
Try this simple step,
Disconnect the power cord from back of printer ( while printer is on )
wait for 10 seconds and connect it back
let the printer Initialize and Try to scan.
IF this does not work, you probably just need to uninstall and reinstall the drivers.
Jul 06, 2010 | HP Officejet 7210 All-In-One InkJet...
Free download HP director for HP Office jet 7410
the hp support wesite should have it---if not, try driverguide.com
May 08, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Windows 7 cant see my hp 6110
1st You download Printer Driver. HP Office Jet Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do you scan a picture?
simply installoffice 2003 and there will be microsoft office tools select microsoft office document scanning select scan new document.....first of all u have to install printer drivers my dear friend
Mar 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have hp officejet 6110 all- in- one and cannot scan page of text into my computer. Printer gives message "Scanning error. Cannot connect to computer."
If you have updated to Internet Explorer 7 or 8, the HP Director program won't work correctly without the update patch from HP Support. Go to HP Support, put in the model number of the device and search for drivers. Look for a special driver or patch for Internet Explorer and download and install. This will allow the HP director to run from the desktop. Once it is started you should restart your printer and make sure it is connected with a USB, or if it is connected directly to the router for your home network, you should uninstall the printer, then reinstall the printer and see if the computer sees it this time with the new driver on the hard drive. Once it installs, see if the HP Director can be started from the desktop and choose scan document, It will ask what you want to scan and where do you want to scan it to. Click document or picture...I have mine set up to scan text documents as PDF's and Pictures as JPGs. I then set it to "Save to file" when the scanning is done, whether it is one file or many, the director will then ask what folder you want to save the files to. That's all there is to it. Good Luck, ParrotHead PC Repair
Sep 08, 2009 | Computers & Internet
Inability ro scan to new laptop
Before scanning from the printer front panel, make sure your Solution Center is properly installed. Try scanning from the Solution Center first. The status of the printer should say ready before scanning.
Thanks,
Mar 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
Hi...
- Actually there are two kinds of CD of the printer, one is the Basic driver CD, wherein you can do basic printing and scanning and the other one is the Full Feature drvier CD, wherein all hp printer software is in including the hp director... maybe you only have a basic driver... i'll give you this site to download the driver of the Full feature software.. this is free. you can also place your order here if you really want a CD... but this download software is equivalent with the content of the CD...
- http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
- select your operating system becuase you did not specified your OS.
- then under driver options select the full feature software driver for your printer
- then next page.. do not select install now or download only because it takes time to perform the process just select file name then select run to start the download
Nov 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
