Question about Zanussi FJD1466W Front Load Washer
Washer problem hi when jetstream starts to fill there are two electrical flashes and bangs from underneath .everything carries normal after this until the next refill,any ideas?
    President:
  • 1,462 Answers
The only major elec item underneath is the motor. you are faced with taking the rear half of the cabinet off and checking where the flash comes from. a possible source is the joint between the two halves of the tub leaking and water from this source will happily drip onto the motor terminals. a second cause is just a faulty motor
Posted on Mar 26, 2007
Water will not fill my washer machine
  1. what worked for me was banging on the top right where the control are - there is a chip in there and every now and then that will happen to mine and I bang on it a few times with the palm of my hand.
Jun 26, 2014 | Whirlpool Cabrio WTW5600XW Top Load Washer
My used washer makes a bang win it goes to wash after the soak cycle. It looks like it is missing springs in the bottom lower front between the motor basket and chassis. Is this suppose to have springs ?
washing machine normally have 2-3 springs on top of the drum and 2-3 shock absorbers supporting the drum from underneath, check one of the shock absorbers has not become detached from the drum or cabinet.
Apr 08, 2014 | General Electric WBSR3140GWW Top Load...
Hi my Servis M4905 Dishwasher has stopped working properly, when you set the programme and close the door it seems to start its cycle but after a few minutes it stops all the lights come on except the...
Hi it may be that the heating element has a fault in other words short circuit, you will need an electrician or a service engineer to check that, as the water fills into the washer it then tries to heat the water first to carry out further duties in the cycle. I hope that this message might help you eric
Nov 14, 2017 | Servis Dishwashers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
May 02, 2009 | Washing Machines
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Mar 10, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine fill but won't go through cycle.
Too empty your machine reset the programmer to Final spin. the machine should empty normally.
If you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Feb 22, 2008 | Hotpoint WMA46 Front Load Washer
Zanussi FJD1466W Front Load Washer Logo
46 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
