Question about Refrigerators
ICEMAKER NOT MAKING ICE
TOP FREEZER ICEMAKER
Hi. since cleaning the ice bin we can,t get the water to turn on in ice maker to fill.alco550
Posted on Mar 11, 2009
  • 36 Answers
Dear Customer
Please perform the following checks
Please rate this ,Thank u
Posted on Dec 17, 2008
My Samsung fridge has two ice makers. The top one is working, the freezer ice maker is not making ice. What can I check?
First make sure the icemaker is not turned off from the inside. Second.,There might be a blockage in the water tube that goes to that ice maker. Clean water tube that supplies the icemaker
Nov 20, 2017 | Samsung Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
The icemaker was making ice but is not now. We
You could have a air block bleed at inlet on fridge.
Be careful and shut off water then unscrew line at fridge put in a bucket and have someone turn the water on for a few seconds. Your line may have become kinked or the water solenoid valve went out not likely. good luck
Jul 16, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker not making ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not working on kenmore top moun t freezer
Suddenly my icemaker stopped making ice. I have a Kenmore ref. with a top freezer.
May 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
I want to install my icemaker it is not working
Pour some water into the icemaker and wait for a sign of ice production. If it makes a batch then fails to produce anymore then check that water valve. If it does tose out any ice at all then check that ice makers connection or get another. Give that puppy 24 hours to start making ice. Read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I just posted my problem with the ice maker
Does your icemaker have a seperate filter that is JUST for the icemaker?
Aug 13, 2008 | KitchenAid KSCS25FKSS Side by Side...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
No ice making
First i would check the water valve in the back. One side is for water.. the other side is for the ice maker... If you have a ohms meter check selonid for continuity look for blisters of plastic on sides showing in would be bad... You can also make a test cord to energise the valve by passing the icemaker to tell if valve is good. ALSO This would put water into you ice maker telling you.. you have a clear path for water to icemaker You only need to plug in for few seconds .. to keep from over filling icemaker if vavle good and water comes thu
Aug 20, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
902 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
