Question about Hotpoint 24 in. HDA1000Z Built-in Dishwasher
NO WATER MACHINE DOES NOT FILL WITH WATER AND THIR IS NO POWER GOING TO THE INLETVAVLE.
    President:
  • 1,462 Answers
If an older machine, suspect the wiring loom where it turns at the bottom of the door. take outer door panel off and carefully examine the loom and pull each wire to make sure it is intact
Posted on Mar 24, 2007
SOURCE:
Ultima 942 wont fill with water, all pipes and filters cleaned, pressure switch replaced, water is on at mains!,fill with jug and machine pumps out ok..any suggestions?
either faulty solenoid or board, turn machine onto a wash and test for power going to the solenoid, if power solenoid is faulty,no power board is at fault
Jul 18, 2018 | Washing Machines
I have a simpson 9.5 kg washing machine an ezi you put powder in and it wont fill you turn the settings to fill and it wont work any ideas i was working fine then now it wont fill up
Power off the machine. Close your wall faucet which brings water into the machine. Unscrew the nut, hold a bag or bucket to collect water coming in from the wall, gently open the water control to see if water flows - the flow should be in good pressure. If it is good, close valve; now open the other end of the pipe going into your machine. You will see a fine filter connected to your machine; clean this out if clogged with an old toothbrush; clean out your pipe too. Refit carefully both nuts, without cross-threading; open the wall faucet to check for leaks. Things should be fine.
Mar 01, 2015 | Simpson Washing Machines
GE washing machine Toploader will not fill with water
see this causes and remedies: God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control. see the diagram attached
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | Washing Machines
It won't fill . the water on. the dryer works but no power going to the wash machine??
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 21, 2011 | Frigidaire FLEB8200DS Top Load Stacked...
Water isnt going into the machine
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Dec 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
No water is going from the tap to washing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 01, 2010 | Washing Machines
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dishwasher overflows when running and when not running still fills without draining
Check the water fill valve - sounds like it's stuck open. Turn the power to the machine off. If water continues to fill into the machine it's the water fill valve. If so...
Take the front lower cover off and look for the valve - it will have a water line going to it. This could also be caused by a bad control board, but look at the water valve first.
May 17, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Hotpoint 24 in. HDA1000Z Built-in Dishwasher Logo
81 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
