Solution #1
posted on Jun 29, 2008
Put 1 cup of water in a 2 cup container.
Add a grated lemon...the peel, lemon, and juice.
Add 5-6 whole cloves.
Boil on high, in microwave, for two minutes.
Let cool completely without opening the door.
Wipe down interior with the same lemon water liquid.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 11, 2007
Vinegar works great but LEMON smells better and works just as good.
Solution #3
posted on Aug 08, 2005
Cornish - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Given the wide range of foods that get passed through it, your microwave oven can get a little smelly from time to time. Usually you can eliminate odors by giving the oven a good cleaning.
1. Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
2. Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
3. Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
4. Reassemble the oven and plug it in.
5. Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
6. Wipe down the oven walls with a clean sponge.
Suggest a new solution for this problem
Post a New problem for Westpoint TV-201 900 Watts Microwave
Email this problem
Email this problem
This Problem Also Relates To:
GE Advantium 120 900 Watts Convection / Microwave Oven
GE JVM1340AW/BW/WW Microwave Oven
GE XL1800 1100 Watts Microwave Oven
GE Advantium SCA2001BSS 950 Watts Microwave Oven
GE JE1590 1000 Watts Convection / Microwave Oven
GE JE1640 Microwave Oven
GE JE2160 1150 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Westpoint TV-201 900 Watts Microwave Oven
Westoint Dishwasher
Westoint Dishwasher
I have looked in the manual... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
