Main cable connector broke off back of TV
Panasonic TV model CT27L8G cable input broke off the TV. Can I just snap in a new connector into the board?
  • 1 more comment
  • Generalidiot Dec 17, 2008
    Thank you kind sir!  I've opened the back up and saw that the cable connector was part of a larger part, ENG36621G, that is called a "tuner".  It looks like it just plugs into the circuit board - do you think I could order this part (found it on Panasonic parts) and replace the broken one or do you think it requires soldering?
  • Anonymous Jan 06, 2009
    Panasonic PT-50LC13 MY Main cable connector also broke..Is ths somethng I can fix or need to go to the shop
  • mikespride42 Jan 14, 2009
    i have the same problem...i took the back off and mine's soldered to the board. do i need a new board...and if so ..whats the part #
    Scholar:
  • 188 Answers
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Posted on Dec 17, 2008
  • rich medrano
    rich medrano Dec 17, 2008
    If it just plugs into the tuner and the cable connector is self contained you can buy the part or maybe find an adapter with the correct plug and jack on either end. Then no soldering is required and you don't have to worry about fussing with a circuit board.
Hi there I have had the Tv for 5 years and it's
I would first check any of your inputs (i.e. cable, satellite, DVD player, ect...). If you hear this buzzing sound regardless of what input you are using, then it has to be the TV. If it's the TV causing it, audio is produced on the main board or A board named by Panasonic. It is the board that has the A/V inputs on it (cable, HDMI, component). This model has 2 different main boards it could use either TNPH0721ACS or TNPH0721ATS. As a TV repair technician, I often use Tri-State Module and would recommend them for parts. If you don't know which board you need, their customer service is helpful. I hope that helps.
Nov 04, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
Broke the Cable input out of the back when moving the TV. Do I need to replace the board and if so do you know the model # and where I can find the part?
that depends on where the break is. may get away with a strip connector if it is just inside the casing of the tv. if broken on the pcb then you will probably require new board.
Oct 22, 2009 | JVC AV-32F475 32" TV
Zeneth A25A11D 25' tv has broken cable connector
Sorry, I miss-read this post. I orginally thought it said your cable broke, meaning the coax that went to the back of the TV.
The coax input is more than likely a part of the main board. I am not a tv expert but as with laptops and input modules that break you have to soder the peice on or replace the whole board.
Easier to switch to a/v inputs as mentioned in Solution #1.
I could not find a spec sheet for your model but did find this for you to give you an idea on what is entailed in replacing a broken RF connection. This may or may not apply to your model, but here it is anyway.
http://www.youtube.com/watch?v=S9v-dUyzdrk
I would suggest letting someone who is qualified in TV repair fix it.
Here are the service manuals for your Zenith. Download both and then extract to your desktop for easy access. I downloaded and extracted myself to make sure it was a working copy so you are good to go.
Part 1:
http://www.eserviceinfo.com/download.php?fileid=34271
Part 2:
http://www.eserviceinfo.com/download.php?fileid=34270
Good Luck!
Oct 16, 2009 | Zenith A25A11D 25" TV
HT762TZ -hdmi off
Try new hdmi cable. Try different inpus on set. Try another known good signal source to determine is tv or souce device if at fault. If aother hdmi connector on set ok then replace main brd in tv, if none of the hdmi inputs work even with known good cable and known good signal sourse the replace main board in tv
Aug 29, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Broken connector, Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo
its solder internally on the board.call the local tv repair person,.they have this spare second hand connectors and will get easily replaced.
Mar 30, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
Feb 18, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Snapped cable input
It all depends on what actually broke. Those input connectors are usually 90 degree metal units, soldered to the circuit board, so possibly the connector took a chunk of board with it. Any competent TV technician should be able to repair this in your home, especially if you tell them what the problem is when you call them. That way they will know what parts to bring.
May 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
1,752 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
