Question about Acer Aspire 5100 Notebook
Acer 4920 Screen fades
My Acer 4920 Aspire, a great machine normally. Monitor has begun fading every so often and can be solved by taking out the AC lead then replacing it. It is then okay for a while then happens again. Could be a power problem but very frustrating
  • craig_roach Dec 17, 2008
    Well it is darker than if it was in powersave mode, so dark in fact I find it difficult to read the screen. So yes darker than on battery or powersave.
    hope this helps
  • Simon Kelly
    Simon Kelly May 11, 2010
    I agree that this could be a power problem. It may be a bad connection between your AC adapter and your notebook. If you can, try another AC adapter and see if this clears your problem.
    There are different profiles in the power options in control panel for when the notebook is on/off AC charge. If you have a look at this, you will see that the brightness is different between the plan you are on for when you are on/off battery power. Does it look like you are on battery power when the monitor loses brightness?
How to fix graphics on 4920 Acer Aspire win7?
There is no sure fire way to fix your graphics card in the laptop, usually they are soldered chips on the board, but if it still works currently, your best bet would be to take an air compressor or a can of compressed air and blow the dust out thru the side vents (NOT THE BOTTOM, as air flows in from underneath you would just be making it worse) chances are its overheating and causing the issue
Jul 10, 2014 | Computers & Internet
Acer aspire 5738 screen fade
From your description, you may either have a bad cable to the LCD on your laptop or the LCD screen itself is going bad. I would guess a repair shop may charge $100-200 for the parts and labor, but you'll have to check your local area for price estimates.
Since your computer is nearly 3 years old, you may want to consider purchasing a new computer, especially since they start at $300-500 brand new.
May 19, 2017 | Computers & Internet
My Acer Aspire One screen is faded. How do i correct this error?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
I require the SNID for an acer and the label is faded.
hiya my compaq pescario laptop keep crashing/screen freezes.my word document is corrupted+ it wont let me delete anything.can sme1 help please
Dec 02, 2009 | Acer Aspire 3000 Notebook
My acer monitor image is faded and washed out
Adjust contract and luminosity: decrease contrast, see how it goes.
ACER monitors tend to have control settings that are out of the range for proper viewing.
Jul 15, 2009 | Acer X191WSD Monitor
My Acer Laptop screen fades or goes out when moved
Try reseating the video cable/connector. Also connect an external monitor to the external video port, power up the monitor first then boot up the laptop. The video image should automatically divert to the monitor, if you see a normal video image then the video card is OK and the problem most likely the LCD screen.
Jun 07, 2009 | Ace Computers Computers & Internet
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Acer Aspire 5100 Notebook Logo
317 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
