RCA M61WH74S screen problems
Im needin help my screens out of adjustment after replacing the bulb and a rather hard bumping the tv got during reinstall. the pincushion is out bad on it its in about 3/16'' total middle from top to bottom i cant find any of the codes for it . i know how to get into the factory service menu i have tried numerous codes for other rca tv's but nothing works any help would be great!!!!
techman
  • 3130 Answers
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
jomaru
  • 337 Answers
SOURCE: Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Posted on Nov 03, 2006
SOURCE: help please stuck in service menu
Techman, I have the following details into Service Mode: 15.1 Quick entry to service mode: TOP PREVIOUS NEXT When minor adjustments need to be done to the electronic controls, the method for entering the service mode without removal of the cabinet back is as follows, using the remote control: Select SET-UP icon, enter ?Program CH? and select CABLE mode in ?Input Setup? option. Select TIMER icon and set SLEEP time for 30 Min. Press ?OK? then VOL up to exit menus. Tune to the Channel 124. Adjust VOLUME to minimum (0). Press VOL ← (decrease) on receiver. Red ?CHK? appears in upper corner. To toggle between aging and service modes: While the ?CHK? is displayed on the left top corner of the CRT, pressing ?OK? and ?VOL? UP on the TV simultaneously will toggle between the modes. Red ?CHK? for service modeand yellow ?CHK? for aging. Press POWER on the remote control to display the service adjustment modes menu, select adjustment by pressing the VOL right/left buttons and CH up/down buttons on the remote and OK to enter the adjustment. Service mode menu TOP PREVIOUS NEXT Have you gotten this to work?
Posted on Aug 10, 2007
fixitallguy
  • 11 Answers
SOURCE: rca p56926 convergence problem
i have a 56 inch RCA Television , with the same exact problem
the tv is now about 12 years old and has been fixed twice for this problem.
RCA is aware of this problem and i fail to understand why they would continue to manufacture a product that is defective and could be unsafe.
you need a tech to look at it . soldering is fix or new board ,
i had two "L" brackets installed to keep the " plug in" board stable .. seemed to be the root of problem. these tv's don't like to be moved.
the tv is serviced by Thompson products U.S.A.
mine broke down right away. and even after three years and a second time . i complained to rca that for three grand i paid for tv ... it better work more than three years or they would be recieving a rather large paper wieght on the front door step.
Posted on Dec 16, 2007
okcfirewall
  • 80 Answers
SOURCE: hi, the vision of our RCA M61WH74S suddenly died.
this is a really hard question to answer due too there are so many things that could have gone wrong to cause this symptom. but to me if it just died without warning you may have a major problem with the motherboard, power supply or video processor. with these older projection tvs its almost always more expensive to fix than it is to replace. because of the parts and of course you have to have someone that has more than a little expertise in this area to fix them. that means you can easily get 500 to 800 + dollars into the repair of an older tv that at the end of its life and may not last much longer.
for 650 my son just bought a NEW 42inch insignia 1080p HD 120HZ LCD flat panel on sale at best buy. let me say I have a 61" projection magnavox that works fine but the picture quality on his when you set these two up next to each other his tv is amazing. so Im going to say if you think you want to try to repair it look around and get the best quote you can before the technician comes out. that will be 50-100 dollars right there and then they never have the right part on the truck to fix your tv in your living room so he must transport it to his shop. 2-3 weeks go by and he finally gets the parts and repairs it then there will be the bill which you must pay first before he brings your tv back that will include transport both ways a bench fee parts labor fuel and tax.
then you realize you could have bought a new one for $300.00 less ouch! If this sounds familiar my best friend just went threw this last year. also if you decide to get a new tv don't be afraid to haggle over the price my sons tv was originally $850.00 and he got it for 650.00 not bad. well I hope this helps some I know its probably not what you want to here but im trying to be honest where most people wouldn't. I hope I was a little helpfull if you have any more info on the tv that would help me diagnose your problem or I can be of assistance to you please let me know
Posted on Jul 25, 2009
I need to replace bulb in a rca flat screen. I'm not sure if it is a bulb or switchboard. Can someone help? Thanks :)
There are no parts available for this unit. If you search eBay or online you may find used parts. There is no bulb the LCD screen would cost more then the value of the TV to replace.
Apr 19, 2018 | RCA Televison & Video
Audio but no picture. New bulb is not blown
Video board problem. Find honest TV Tech.
Oct 28, 2013 | RCA M61WH74S
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
222 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
