Computers & Internet Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i can't find the prolink 1456 pva modem driver.pls give me the driver.
  • amitalee Jan 19, 2009
    hi i can't find the prolink 1456 pva modem driver.pls give me the driver.
    its version no is 1.0
Florin
Level 3:
  • Master 733 Answers
  • Posted on Jan 02, 2010
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166405
Points
1640
From this site you can download it http://drivers.softpedia.com/progDownload/Prolink-1456PVA-Modem-XP-Driver-1700-Download-43085.html
Prolink h5201
No. You must use a 5V ac adapter/power supply.
But are you certain that you need 5V ac to power your modem ? Where are you located Jane ?
22.April.2014
Belkin F5D77230-4 - connecting to modem
It would seem that:
Your modem has only USB output;
Your Router has only Ethernet input with WiFi & 4 LAN port outputs; and
You want your laptop to be access the Internet through wireless connection.
There are USB to Ethernet converter/adapter, an example is shown here.
There are on the otherhand, comparable modems to what you have that provides both a USB and an Ethernet output such as the ProLink H9000 shown here .
Perhaps your best course of action is give your provider first a call and see if you can require them to replace your modem with another model/version, one that has an Ethernet output or a combination.
Alternately, a way can be configured if you have a desktop that has both a USB and Ethernet that we can set up as Gateway (but this is the long method).
Hope this be of some help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
4helpful
2answers
H9601C prolink modem driver
i cannot install prolink h9601 adsl modem on windows xp home edition,, any luck??????
7helpful
3answers
I lost my prolink web cam drivers and software
I am making the assumption that your web camera is the Prolink PC1320. If it is the try the following link:
http://www.prolink2u.com/downloads/drivers/accessories/PCC1320_Driver.zip
If this isn't the driver that you need, please let me know and include the model of the camera that you have. I will then find the correct driver/software for you. Binary Bob
12helpful
4answers
I need a audio driver for my versapro va10h window xp
http://support.necam.com/Drivers/index.cfm?M=539
this is the link of nec versa pro drivers
4helpful
14answers
Windows Vista CDMA 1X usb modem not working
I faced the same problem i installed it. But got through it. See if this works for you too:
1. You have to install the software you downloaded from the tata site or from the CD you got with the MODEM. Do this without attaching the MODEM to the laptop.
2. Once done, insert the MODEM into the USB drive. The Windows will automatically search drivers for USB MODEM and QualCoMM drivers and install it.
After it shows the success message, click the Tata Indicom Dialer and check. The problem should not appear again.
Bridge mode
i see,, seems your router is not configured, you can try an alternate way.. if you have windows xp, goto control panel select internet options, goto to connections tab then click set up button a wizard will pop up, click next then select connect to the internet then click next, select set up my connection manually,, select connect using a broadband connection that is always on then finish...
Sandrew
try here,http://support.gateway.com/support/drivers/dlcenter.asp
left side "driver and download search", type in your model and go
there were a few different modems for that modle and they seem to list them all
Grand Canyon Tech
Grand Canyon Tech
