Question about Vizio L37 Television
Frame periodically freezes on Vizio 37'' TV
This TV is hooked up to an antenna with a booster. In the last week, it has frozen two times. The first time it was 1 1/2 hrs. later that I returned into the room and saw it frozen on the news station at 8:29 AM
  • 3 more comments
  • kathykul Dec 22, 2008
    My tv is hooked up to cable and freezes after being on for about 3 hours. The only way to shut it off is to unplug it.
  • Anonymous Dec 28, 2008
    my tv freezes permanently within 5 minutes of being on. nothing works the remote nor the buttont. strangely the sound continues while the frame remains frozen. any solutions?
  • Anonymous Jan 30, 2009
    freezes more and mor often i just un plug it then plugit back in i think its a defective tv tuner/processor bc externall inputs are not effected
  • solusob Feb 14, 2009
    I have a similar problem on a Vizio 37" LCD tv. The screen freezes (frozen) and the remote ceases to work. You can't do anything. NO buttons work, I have to unplug the tv and plug back in to get working again. It has done it twice in the past few hours but never has before. I have a fine digital signal verizon fios cable so the signal is not the issue.
  • Anonymous Apr 19, 2009
    My Tv started doing it when I had to use the High number Rf Channels after cable said you needed a box. the Channels not available without a digital box were still available on Vizio Rf channels. But after hours on one of those channels it will freeze the picture with no sound. Nothing works but unplugging.
    But It ONLY happens with the RF channels. Gonna contact Vizio.
HELLO to the guy saying hello ... I am on cable and have the same freezing problem ... so take the attitude and shove it!!!!!
Posted on Dec 19, 2009
I am experiencing the exact problem with my vizio. It is 2 yrs old old this has occurred about 3 times in the last month! Sometimes the picture is black othertimes it is frozen on screen. I am a cable customer and have had the unit adapted for HD .Yhe only cure is to unplug it and wait and restart. SDUCH an ANNOYANCE, Vizio will do nothing and says it has not one other documented comlaint of this nature... REALLY??? what can we do now??
Posted on Feb 05, 2010
  • chrisapirie Oct 01, 2010
    Wachusett`s note just about hits the answer. It happens in Southern England via TV reception from Sky and whilst TV goes into freeze frame the audio continues. Until improvements are introduced the only solution is to switch off TV, then switch TV back on and problem has vanished.
    Novelist:
  • 152 Answers
Hello, your picture freezes becuase your using unstable reception like over air analog signal antenna. even with a booster you still loose signal if theres storms or weather events. try using a more stable signal like cable or satelite service even digital adapter for digital tv this may help with the freezing.
Posted on Dec 17, 2008
2 Suggested Answers
  • 1779 Answers
SOURCE: Frame periodically freezes on Vizio 37'' TV
Your statement is confusing. Why? because you stated " This tv is hooked up to an Antenna with a Booster", then you said it's connected to Cable Tv. I will answer this both ways for you.
If your on an Outside Antenna or Rabbit Ears, even with a booster, if the signal is not good prior to getting to the antenna then a booster only amplifies what it see's and that may be as we call it, "garbage". In a HDTV the freezing can happen when that situation is at hand, however if you are on Cable and we know the signal is clean ( we hope? ) then the problem is with the software in the set and should be looked at by a service center, or if it's right out of the box then I would exchange it.
In digital technology there's no maybe, it's yes or no! If the signal is not what's required, then you get what your experiencing now, IF, there's nothing wrong with the set, and there may be. I just repaired another brand doing the same thing and it was the Main Control Module. So, I hope I helped you in isolating the problem. Please keep me posted...
Posted on Feb 26, 2009
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
The picture on our Vizio V0370M periodically gets darker, then after a while will lighten up.
If this is a brand new TV you may have a bad video card. The other, easier but pain in the but thing is you could be switching from a HD channel to a non HD channel. You will notice a difference. Last if you have an light sensor on the TV (adjusts to surrounding light) that could be tripping but you should have an option to turn that off.
Jun 16, 2011 | Vizio M370NV 37 in. LCD TV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
Same problem
Then I would say you have a problem with the Main Board in the 37". Have it looked at by a service company in your area if he wants to work on a Vizio. Parts are difficult to obtain at times.
Jun 08, 2009 | Vizio L37 Television
Feb 26, 2009 | Vizio SV420XV 42 in. LCD TV
Just the one TV freezes
hello, it possible if your sharing the signal to sometimes loose reception you should have a dedicated hdtv antena or hdtv cable service for your main tv.
you can check by removing all the other sets and see,
if it happens again then you need a dedicated hd antenna or signal. this should be better for you and your hdtv reception.
Dec 17, 2008 | Vizio VU37L 37 in. LCD TV
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
Vizio L37 Television Logo
3,856 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
