Question about SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
I plug in my player and it says Load main image failed switsh to recovery mode!! I can even get my computer to connect with the player -- it doesnt recognize it when i plug it in. So ya I cant do anything with it I cant even go into my computer because its not there. Can anyone help??!! PLEASE!!!
  • 3 more comments
  • Alina Pruner Mar 24, 2007
    this is Alina and this post is wrong I put in another one!! Sorry didnt check my spelling before I entered it.
  • unfraggle Dec 07, 2007
    my mp3 sansa 4.0GB won't even turn on.when i connect it to my computer,itturns on,says connected then fades away.the computer will then show no device connected.this is the first time this has happened since i got it in august.help!
  • meetwins Apr 21, 2008
    Same problem and when I download the fix, nothing happens to the player. I can't even find the downloaded fix. Help.
  • Anonymous Jul 01, 2008
    i can get to recovery mode but i dont know what to do from the i dont now what to press or where to go please help me
  • Anonymous Mar 22, 2009
    yea me too the link isnt working
Muitíssimo Obrigado ;)
Posted on Jun 06, 2008
My name is joel
am having the same problem
but the link is not working
http://www.sandisk.com/Assets/File/Downl...
Posted on Dec 01, 2007
  • adenaur Dec 01, 2007
    having the same problem here
    the links isn't working
Thanks So Much Syd
Posted on Nov 26, 2007
It didn't work
is there another solution that works?
please help
Posted on Oct 28, 2007
    Scholar:
  • 47 Answers
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
Posted on Apr 24, 2007
2 Suggested Answers
SOURCE: HELP ME PLEASE!!!
ok i followed all the steps till i got up to step one, once i click the link to open the page, it said the link had a error and it relocated me somewhere else.
Posted on Dec 24, 2007
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
H ELP!!!
help....
load main image failed...switch to recovery mode
Feb 22, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
Recovery mode
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 02, 2007 | SanDisk Sansa e250 MP3 Player
Load main image failed?
Hope this would help. Have you updated the firmware of your player? Try updating the firmware of your player. When the player is turn off slide the hold switch for it to show orange/red color. Then press the Record and the menu button until is shows on the screen welcome to recovery mode. Then go to sandisk website and download the firmware update and install it to your computer. When it ask you to connect a device connect the player and update the firmware of the player. If the update is successful then it would ask you to choose a language. Hope this helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
My maing image fails to load
what you should try to do is plug the sandisk in your computer then put the sandisk on hold and hold down the menue button till it says its in recovery mode.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
232 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
