Question about Grilling
Heating my weber grill genesis 1000 does not seem to heat as effectively as it used to low flame when all dials are on HI
  • 1 more comment
  • brownfield12 Jan 04, 2009
    the grill only reaches about 275 degrees, natural gas, ten yrs old. thanks.
  • laone Feb 07, 2009
    Burner is low even though control is set on highest setting. Replaced propane tank with no improvement.
  • Anonymous Mar 03, 2009
    The Brinkmann 4 burner grill is on hi and the flames are maybe a half an inch long. It is pitiful
When you turn on the main propane value (on the propane tank) do it real slow and easy. What might be happening is that the regulator on the unit is sensing too much propane at one time and is shutting down the flow. If this happens, you only get a small flame. You need to shut it down, wait about a beer, then try again REAL SLOW AND EASY.
Remember, slow and easy; as soon as you hear some gas going though, stop and see if it works. You can open the valve further if needed but take it slow.
This is how I made my Weber Q work after about 6 months. Now, it's great. I have to wrestle with it but at least it works now.
Posted on Apr 29, 2009
Vapor lock.?
Posted on Jan 23, 2009
Do the weber gas grills use lava rock?.
Short answer ...No. They use a flame tamer or flavorizer (the tent like things over top of the burners. Lava rock, would cause uneven heating.
May 29, 2011 | Weber Genesis Silver A Grill
Temperature will not reach past 180 degrees
you may need a grill clean or you need to adjust the air flow to your burners
Apr 20, 2010 | Weber Genesis Gold B Grill
Silver C 2000 Model heats to 420 degrees with all 3 burners on Low. Normal? Weber support service has given me conflicting information. With 2 burners on Low it heats to 310-320 degrees.
That's fairly common with the lid closed and a day that is not too cool. Keep in mind that a gas flame is about 800F. Try using only one burner on low or between on and high to get a lower temperature. This is a grill, not a smoker or slow cooker.
It will run cooler with a large amount of food.
Feb 08, 2010 | Weber Genesis Silver C Grill
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Low heat from weber grill
turn tank off disconnect from grill make sure all knobs are turned off including side burner reconnect tank make sure fitting is all the way on tank turn tank on and try again
Aug 15, 2009 | Weber Genesis Silver C Grill
Very low heat
the air control is at the back of the burner control.
you may have to disassemble the control panel in order to get to the air control.
may sure the air control is open all the way.
Oct 19, 2008 | Weber Genesis Silver C Grill
Uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Oct 17, 2007 | Weber Genesis Silver B Grill
Grilling Logo
647 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Grilling Expert? Answer questions, earn points and help others
