Question about Quasar VM-L153 VHS-C Camcorder
Tengo una Quasar VM-L153D, al grabar el sonido no funciona, ?¿Que debo hacer?Gracias
4 Suggested Answers
SOURCE: power adapter for quasar 1987 video cam vm-21
how do you use the acadapter for model 458
Posted on Dec 13, 2007
SOURCE: dew warnig de camara Panasonic Quasar
LA HUMEDAD CON EL CALOR ALTERA Y HACE QUE EL SENSOR DE HUMEDAD DE LA CAMARA SE ACTIVE. YO PROBE CON UNA SECADORA DE PELO DE MI MUJER Y ME FUNCIONO. LA CAMARA AHORA ESTA BUENA. HABRE EL MECANISMO DEL TAPE (CASETERA) Y SOPLA CON EL SECADOR DE PELO DURANTE UN RATO DENTRO DEL MECANISMO DE LA CAMARA TAMBIEN ALRREDEDOR DEL LUGAR DE LA BATERIA Y ALRREDEDOR DEL BOTOM ROJO REC-VHS-OFF, DEJALA HABIERTA UN RATO Y PRUEBA DESPUES PONIENDOLA A FUNCIONAR. DEBERA FUNCIONARTE CORRECTAMENTE Y SIN EL WARNING-DEW DETECTED
Posted on Sep 06, 2008
  • 814 Answers
SOURCE: connect my Quasar VHS palmcorder model # VM-L152 to my macbook
To find this information you will have to either go to the Panasonic customer support website and enter your palmcorder model number and check out the frequently asked questions to see if they have already asked this question and have a answer in the form. the website is (http://www.panasonic.com). you can call the customer support telephone number at 1-800-211-7262. Between the hours of 9am-7pm EST. You can also use the customer support e-mail at www.consumerproducts@panasonic.com Give them the Brand name and model number of the palmcorder and ask them for the correct connection procedures to use the palmcorder with your computer. I Hope this information helps you with your palmcorder problem.
Posted on Jun 10, 2009
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
NO APARECE MI CAMARA WEB QUE VIENE INCORPORADA A LA LAP, COMO LE HAGO, DICE QUE NO SE ENCUENTRA O QUE ESTA OCUPADA O QUE NO TENGO, QUE DEBO COMPRAR UNA Y ESO NO ES POSIBLE, POR QUE SI TENGO CAMARA WEB,...
que hago tenia instalado en mi pc oficce 2003lo cambie por 2010 pero cuando quiero reproducir una presentacion de power poit dice que no se encuentra el punto de entrada del procedimiento except handler 4 common en la biblioteca de vinculos dinamicoas de msvcrt.dl que devo de hacer por favor quien me puede ayudar
Feb 24, 2011 | Computers & Internet
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
No me Funciona El compresor ni El Abanico del aire de El Que esta en la maquina de Cuando lo enciendo
Tengo una cosola Trans de consola de 240000 BTU cuando me la istalaron no funcionaba movieron el abanico y funciono.. aparentamente es el abanico. Actualmente esta funcionando. Que debo hacer.
Aug 20, 2010 | Heating & Cooling
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
No tengo sonido
ABre el programa de Windows media player, debajo de library oprima el botton que dice "options". En options oprima el botton que dice "devices". Orpima donde dice "speaker", camie el audio device. Buena suerte. Israel
Mar 22, 2010 | ASUS Computers & Internet
Tengo una lavadora LXR7144EZ1 Empezo con un ruido
Mil gracias por tu ayuda, la lavadora cuando llena no hace ningun ruido, luego cuando empieza a restregar empieza un ruido fuerte y despues de esto se detiene por completo, muchas veces a trata de llegar al ciclo de exprimido. Pero el dia de ayer dejo de funcionar completamente.
Sep 01, 2009 | Whirlpool Washing Machines
GR-DX75US
Hola Lucio
Yo sot de Argentina y me pasó lo mismo que a vos, llamé a representante en Argentina y me dicen que ellos no lo pueden arreglar porque la camara fue comprada afuera de Argentina, esto es una locura ya que en todo el mundo las están arreglando gratis. Decime como hiciste si es que lograste solucionar el problema
Saludos
Nov 15, 2007 | JVC Cybercam GR-DX75 Mini DV Digital...
PROBLEM CON SOUND AND TV
Parece que su problema es solamente de configuracion fisica and programacion. Empesando conecte su cable al televisor y programe por el menu los canales que se van a recibir por el cable y no por una antena exterior. Sin el cable puesto y el televisor prendido y el volumen alta debes de poder escuchar sonido rasposo porque no hay imagen. Si acaso hace eso entonces tu televisor no tiene problem electronica y es como dije anteriormente. Buena suerte y dejame saber algo. Que Dios lo bendiga.
Sep 07, 2007 | Apex Digital AVL2776 27 in. HD-Ready LCD...
Quasar VM-L153 VHS-C Camcorder Logo
16 people viewed this question
Top Quasar Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Quasar Video Camera Expert? Answer questions, earn points and help others
