Question about JVC KD-G801 CD Player
JVC Kd-G801 Just got this cd player wired up in my focus last night and not sure how to use it, i can get the cd player to work but not my sony 10disc multichanger from my last cd player i have, and also how do you change modes so i can put on mp3, wma ect, and what connection do i need to connect radio up connectors at moment look exactly same
    Top Expert:
  • JVC Master
  • 49,942 Answers
Try Googling (JVC)(KD-G801)(manual) without parens for information.
Posted on Nov 08, 2017
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
SOURCE: Connecting an Ipod to a JVC KD-G310
Try this, you can connect thru CD Changer Input, that called J-Link. There is cables, that goes from J-Link to 3.5 mm jack.
So you need to buy on the ebay "JVC J-Link to 3.5 mm".
Best regards, Zhenya.
Posted on Jun 02, 2009
etirbynnor
  • 655 Answers
SOURCE: connect jvc kd-lh1150 in elantra 2001... different
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Posted on Jun 05, 2009
SOURCE: How can i turn the aux option on on my jvc kd-g801
it's not for running your ipod or whatever else, it's for steering wheel control for those cars that have the feature. that's what it says in the manual anyway, there's gotta be a way to run the ipod through though for sure
Posted on Jun 06, 2009
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
JVC KD-G801 CD player has light on (on) button but doesnt switch on when pressed
Look for a pinhole button on the face, just left of the #1 radio preset. Use a ball point pen or paper clip to lightly hold this button for 2-3 seconds. You may do this with the key on. This will reset the radio's microprocessor.
Let me know if this helps.
Dec 18, 2013 | JVC KD-G801 CD Player
Carnt get external jack plug to work
Which external jack plug? Please be a bit more specific
Sep 25, 2013 | JVC KD-G801 CD Player
Just bought a brand new jvc cd receiver and it won't turn on.
Please check if the wiring was done correctly. check the ground the all time +12 volt and the swittched +12 volt. If the set does not power up then I suggest that you MUST take the warrranty claim being a new set. Refer to the dealer before you can open the player so as not to void the warranty
Jul 02, 2011 | JVC KD-G801 CD Player
I hooked my head unit up and it wont power on yet if i put a cd in it will come on recieve the cd and turn back off also the disp turns it on for a second. what is this?
you need to make sure 3 wire are connet the right way one is constant power,2 ground,3 acc. ingnition also there is 1 more wire you need to connect is the remote blue or blue/light blue.
Dec 27, 2010 | JVC KD-G801 CD Player
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
Hi I have a JVC KD-G801 car cd player/radio. Today a mechanic uninstalled it from a car I have which I will be selling and he installed into a newer Peugeot 306 I bought at the weekend. The stereo is...
Yes... the wire designated for constant power which powers the clock and some of the lessor memory functions is disconnected.
I would remove the radio and look for the lead that is disconnected and have a constant power lead attached to it to cure this issue.
Have the mechanic who did it the first time do it.. as it was already paid for him to do so in the first place...
Oct 06, 2010 | JVC KD-G801 CD Player
I have removed my JVC KD-G801 from my car but realised that there is still a CD inside the unit. How do I remove it?
Hook your power wires and ground up to a cordless drill battery , 12 volt, or 14 volt. Or use jumper wires from car battery. Hit eject. You don't need all the speakers etc hooked up.
Feb 13, 2010 | JVC KD-G801 CD Player
How can i turn the aux option on on my jvc kd-g801 in car cd player to enable my ipod to work
Apr 18, 2009 | JVC KD-G801 CD Player
Installing a cd deck into car
BUY THE HARNESS ON WALM MART IS GOING TO BE MORE EASY IS ON THE CAR ACCESORIES DEPARTMENT
Mar 18, 2009 | JVC KD-G120 CD Player
JVC KD-G801 - Buttons not perform correct function
disconnecting the main harness will reset the microprosessor it is possible that it just locked up and resetting the unit by unplugging it may help. or you might have a bad switch in the face of your unit
if unplugging your jvc doesn't help you can e-mail me at merle@aol.com
Oct 01, 2008 | JVC KD-G801 CD Player
JVC KD-G801 CD Player Logo
61 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
