Compressor runs 15 seconds shuts off for 2 to 4 minutes runs 15seconds ect. ect. ect.
SOURCE: magic chef portable freezer not cooling.
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
SOURCE: I have a magic chef freezer MCCF5WBX the power
Had the same problem for the same unit. In my case, the theromostat was sticking. Mine was still under warranty so I called Magic Chef, who in turn gave me to a local repair person. In order to save him time to travel out for a diagnosis, he asked me to tap on the control to see if the run light comes on. Sure enough the run light came on and cooled the freezer. Try tapping on the unit control to see if it kicks on. My email address is [email protected]. I'd like to know if it works.
SOURCE: Power light is on but run light will not come on. Freezer no run
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
