Question about Admiral AW22 Top Load Washer
WON'T SPIN DRY
WATER RUNS IN, WON'T SPIN OUT--TOOK OFF BELT & MOTOR DON'T TURN OVER. NO SMELL OF BEING HOT
ADMIRAL mode-- LATA300AAE admiral model# LNC6760B71 wont spin out. makes a buzzing sound
  • 108 Answers
You need to check if there is power to the motor. If so the motor is defective.If not, the timer may be the problem. There should be a wiring diagram on the back of the unit. Using a voltmeter, trace the power.
Ray
Posted on Dec 17, 2008
Avv8000agw slow spin and smelly
First of all check if the motor is hot or there is friction on the drive. Since you had noticed some smell then the best option is to trace the smell which must confirm the case. It could be the motor or possible capacitor or within the power supply or drive output.
Jul 03, 2012 | Admiral AW22 Top Load Washer
ADMIRAL WASHER MODEL NUMBER LNC6753A71 HAS BURNING SMELL AND WON'T PUMP AGITATE OR SPIN BUT MOTOR IS RUNNING
its probably the drive belt that you smell burning under the basket,but there are numerous things that can cause it to burn,so you need to find where its froze up could be a clutch,the brake,the drain pump
Aug 02, 2011 | Whirlpool Washing Machines
Smells like belt is burning in 1st load of laundry. smells hot
The belt or belts transfers power from the motor to the transmission and pump. If the belt fails, the washer will be unable to pump out the water in the drum nor will it be able to spin the drum or operate the agitator. The washer will sound as if something is running (the motor) but everything under the lid will remain motionless.
The belt is a replaceable part. If you smelled the belt burning, chances are it has been stretched or is missing chunks and is damaged. It should be replaced after unplugging the washer and disconnecting the supply hoses. Next, determine that nothing is jammed and everything moves as it should. This would be the pump and the transmission. You'll probably have to turn the washer on its side to access the belts. Be prepared to mop up water that will spill once laid on its side. If pump or transmission is jammed, the motor will probably burn up the new belt, too. Make sure nothing is preventing the agitator from working - this could be clothing wrapped around / under the agitator. It is possible that something has become lodged in the pump housing. You won't be able to see it - but you should be able to turn the pump - if either of these won't turn, you'll need to get them turning freely before you can expect the motor to spin the belts.
I hope this helps and good luck! Please rat emy reply. Thank you.
Apr 05, 2011 | Admiral Washing Machines
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Admiral lnc6760b71 Problems - Strong smell of burning plastic or rubber last week. Now the machine will stop when full of water and not respond. Later it will continue by itself. I took of a small panel...
Same problem, same model admiral. The smell is motor overheating. Once cool enough, it will continue with it's cycle. I took the top off and watched it run. The motor stopped and smoke rose from the motor located at the front right corner. I am scrapping mine and buying another washing machine. This admiral has been trouble since we bought it 5 years ago.
Jul 11, 2009 | Washing Machines
Squealing while in spin cycle
normally, slow then build up of speed is a sign of the motor brushes wearing. this may cause squealing under load. the pump pulley may be hard to turn due to hard water calcifying or a build up of dirt... you may want to check the pump out before it becomes another problem. also,are the bearings in the drum dry? the belt also does not need to look as though it is about gone before it needs replacing... it could be that the belt is slipping whilst under a faster loading... try some belt grip spray to see if this cures the noise.if it does,then you are certain you need to replace the belt(s)
regards
Dec 08, 2008 | Admiral AAV7000A
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    My Admiral waher model # LNC6762B71 will not spin or drain
    with the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
    it it does then you have a transmission problem
    if the motor does not run then there is a electrial componet problem
    May 17, 2008 | Admiral AW22 Top Load Washer
    Admiral mod#lnc6760b71
    Water runs out, but does not spin, nor dry the clothes. Motor is good.
    Dec 08, 2007 | Admiral AW22 Top Load Washer
    Admiral AW22 Top Load Washer Logo
    279 people viewed this question
    Top Admiral Washing Machines Experts
    Sal De
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
