Question about RCA F27650 27" TV
Tv seems to be in widescreen
The problem is the TV seems to be in widescreen, however the TV is a basic 4:3, with no 16:9 option anywhere in the menu. We just turned it on one day and all of a sudden most of the left and right was off the screen. here is a picture I drew to try to describe the situation. http://img.photobucket.com/albums/v399/Bakudai/tv.gif This is a problem with the TV itself because the built in menu and numbers also go off the sides a bit.
  • 81 Answers
You have a defective cap and diode in the horzontal section of the TV. This unit is best off sent to a tv shop where replacement cam be done for thr diode and cap are special components for the RCA
Posted on Apr 06, 2007
Turn off widescreen on element elchw261 tv
Select menu in remote control, select format, change ratio size to fit your screen. If you do not know the correct format, you may have to try all the options.
Jul 04, 2012 | Element Electronics ELCHW261 26 in. TV
We own a proton pltv-32c. the image coming in is larger than our screen (or the ratio is off). Basically the top and bottom of all images are being cut off (same for TV and video watching). What to do?
Check the FORMAT option in the OSD (on screen display) menu. It may need to change.
It's on page 15 of the User's Manual.
Format
Controls the picture format. The options are 4:3 and Full
(16:9-widescreen).
Or you could reset the tv by using the All Reset button on the menu.
All Reset
Resets all options to factory-default settings.
See page 23 of the User's Manual.
You can get a user manual from;
http://imageuploads.googlecode.com/files/PLTV-32C-owners-manual.pdf
If you do not have Adobe Reader to read the manual you can get it from;
http://get.adobe.com/reader/
Mar 27, 2011 | Televison & Video
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
Picture too big so faces long and narrow, how must i zoom out to make pic smaller
If the image is tall and thin, then you've likely got your TV set to widescreen mode when it's not a widescreen TV. In your TV's menu, there should be an option to change between widescreen and normal, or one called "Aspect Ratio" and it'll give options like 16:9 and 4:3, change that to 4:3 if that's the option it gives you.
Jun 05, 2010 | Televison & Video
I have a Pioneer DV-525 DVD player, and recently upgraded from a 4:3 TV to a widescreen TV. However, under the Setup menu, it won't let me change the setting to 16:9. The options are grayed out, and I...
The DVD movie has to be a "widescreen" version...
Check the cover of your DVD movies ... there may be one or more widescreen DVD's in your collection...
That should work.
What widescreen TV did you get? Brand / model.
If it is Samsung ... on the remote, press the "p.size" button (and wait) ... continue pressing and waiting after each press to see if the Samsung will adjust ... You may get a distorted pic ... like very short and very wide people.
What TV Brand / model??
Sep 14, 2009 | Pioneer DV-525
How to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 18, 2009 | Insignia IS-LCDTV32 32 in. Television
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Feb 20, 2008 | Televison & Video
Shows as widescreen instead of normal view
try using the tv remote to change the screen size and keep changing it until you find the correct size
Oct 21, 2007 | Pioneer DV-525
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
140 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
