Question about Toastmaster Kitchen Appliances - Others
Paddle won't turn to mix ingredients
We got this and it worked the first time. Second time we went to use it, none of the ingredients were mixed. The paddle doesn't turn during a cycle. But if we remove the bottom panel and turn the wheel the belt is connected to, the paddle does turn.
  • 368 Answers
If it's that new, I'd return it for warranty work or refund.
New equipment is supposed to work.
For Toastmaster parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/tm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Jan 04, 2009
My bread maker paddle is turning correctly, but it is not mixing the ingredients. We put liquids in first. The first time we used it, it was perfect?
You may have too dry or too watery a batter. Check your ingredient mix for accurate measurements.
Recheck the unit without ingredients in place to be absolutely sure you have the paddle seated correctly. Although most are designed to make it very hard to put the paddle on incorrectly, old dough or batter may harden in place and keep the paddle form fully seating correctly.
Mar 01, 2015 | Regal Ware Kitchen Appliances - Others
Bread maker paddle won t turn
You may need to replace your belt. Sometimes belts will slip if they are older models. Newer bread machines have belts with tiny teeth or cogs in them that align with the cogs on the pulley wheels. They don't slip like the older serpentine belts. sometimes a new belt will help. There are several videos on you tube of how to replace and install bread machine belts.
Jan 27, 2014 | Kitchen Appliances - Others
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
Timer went off and I went to get what should have been a finished loaf of bread. What I found wad a loaf cooked kind of hard in the middle and lots of uncooked dry mix all around the outside rim. It looks...
Hi, Sounds like the paddle inside the bread pan did not mix the ingredients very well. Take the pan and paddle out of the machine and see if you can turn the paddle freely by hand. Yes is good..if it sticks then the sealed bearing is failing. Next, keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft turns. The belt may have fallen off or is too loose and the paddle won't turn freely under load. The belt, pulleys and motor are inside the base of the machine. Hank
Mar 15, 2010 | Breadman TR2200C Ultimate Bread Maker
Sunbeam 3500 does not mix properly
It could be that the belt is slipping, or the sealed bearing in the bread pan where the paddle goes on is sticking and not mixing the ingredients like it should.
Feb 09, 2010 | Kitchen Appliances - Others
Oster 5834 not mixing ingredients well before rising & baking
Take the bread pan and paddle out of the machine and see if you can spin the paddle by hand. If it moves freely, then it could be the belt is loose on the pulley inside the base of the machine, or the pulley or motor itself is not right. Either check the belt or exchange it at the store or check warranty. It is obviously a defect. Good Luck, Hank
Jan 20, 2010 | Oster 5834 ExpressBake Bread Maker
The ingredients aren't mixing. I have to take the dough out and
My experience with the machine is that it kneads perfectly, but you have to use ACTIVE DRY YEAST instead of another kind of yeast, and you have to throw the ingredients into the pan in order - do not mix the ingredients at all - just pour them in, and let the machine do the mixing. Except for substituting between BREAD FLOUR and WHOLE WHEAT FLOUR, do not substitute any other ingredients. This one is very picky about the type of ingredients that you use - not for the innovator :-)
-Tha Mp3 Doctor
Feb 06, 2009 | Cuisinart CBK-200 Bread Maker
What is a kneading paddle in tr441breadman
It mixes the dough. All you do is put the ingredients into the bread maker, turn it on and wait. It will do all the work for you.
Jan 03, 2009 | Breadman TR444 Bread Maker
Kitchen Appliances - Others Logo
73 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
