Question about GE Profile DPSB619ED Electric Dryer
Condensation build-up in the dryer drum, clothes remain very damp
I cleaned the lint filter with a flexible long handled brush and then blew out loose lint with leaf blower. I also ran brushes all through the exhaust flu pipe and used leafblower in it as well so it is clear. External lint basket is clear. Heating element is working and the exhaust fan is working as well. I'm really stumped on this.
  • wnschool78 Dec 18, 2008
    The clothes remain very damp. When I open the door to check on the results, my glasses fog up, as though I were entering a steamroom. There is condesation on the door when I open it. When I used a brushing system in my exhaust pipe to push through a possible blockage, the rods, which assemble together were wet when I pull them back through.I have a Maytag Performa, not an expensive model.
  • Dave May 11, 2010
    Is it taking longer than normal to dry?
  • 113 Answers
You deffinately have some sort of blockage in your exhaust vent, most likely in the wall. Check the outside vent on the outside of the house. The air should be blowing pretty hard. hope this helps. Dave www.washermd.com
Posted on Dec 18, 2008
Hotpoint WDUD9640 washer dryer clothes coming out wet and hot
check the exhaust tube externally and internally for excess lint build-up on the sides. You may not have the vent obstructed, but you may have the venting restricted. Clean out lint if there is excess. It may need a good scraping/ brushing to help your machine breathe. Just an extra thought.
Mar 11, 2018 | Hotpoint Dryers
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Dryer heats up and finishes cycle, but clothes still damp. It actually smells like something is burning. I already checked and redirected the hose, blew the pipe leading outside, cleaned the filter and...
check air flow were heat exhausts outside. good air flow? sounds like lint clogged. couuld be in dryer, in exhaust hose, id start with hose make sure clear and not kinked.
Mar 10, 2014 | LG DLE2532W Electric Dryer
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
Why is my Maytag Bravo steam dryer leaving my clothes damp
If there is water in the hose, water is getting in through the vent on the outside. Try cleaning where the flap on the vent rests of lint and build up. Also check that the vent is fastened in the ground. If it's loose, water will seep in around the seal and get down into the hose.
May 12, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Heating up but not drying clothes
Your vent could be clogged with lint and debris. First remove the lint filter and clean the visible lint. Then run it under warm water and use a soft brush to gently scrub to remove any chemicals from softeners that may be on the filter. While the filter is drying completely, use a dryer brush (available at most stores that carry appliance accessories) and clean out the vent as far as the brush will reach. Next go to where the vent exits your building, lift the flap and clean that area as well.
What happens is that lint builds up over time. The heat and moisture causes it to matt up and it can't be blown out by the mild wind force created by the dryer. The only way to get the matted material out is to clean with a brush and remove it.
I hope this helps you. If it does, please come back to Fixya and rate my advice.
Jul 27, 2011 | Bosch Dryers
My dryer keeps showing clogged lint filter. I have cleaned the filter and the area under the filter. How do I clean to the exhaust tube? It is leaving my clothes damp, but the dryer is getting very hot...
You should post model number and manufacturer for better answers, but all dryers have an exhaust duct that builds up lint in it over time. I take mine apart every few years and it always has lint built up in the exhaust before it even gets out to the vent pipe. Mine is a Kenmore/Roper, and to take the exhaust duct out you take out two screws from the top under the lint filter door, and then take off the back cover and remove four screws from the duct itself. Then I scrape it out and/or vacuum it with my shop vac. I'm heading away from the computer for the night, but if you post model information I'll take a look tomorrow evening, or one of the other experts here can help you out.
Best wishes, and thanks for using FixYa!
May 03, 2011 | Dryers
My dryer has a build up of water and give an F03 error. What can do to fix it?
have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
Dryer Door Clouds over with Condensation. I found
Your dryer is not venting to the out-of-doors. Try removing the vent tube from the rear of the dryer and checking it all the way to the outside for an obstruction,i.e. lint build up, water retention, animal nest, etc. Make sure there are no sags if it is a flexible vent tube, no pinch off points, short as possible... most dryers can only have a 10-15 ft. length of straight tubing. A mechanical failure of the blower could also cause the issue.
Illeagle
Jun 14, 2009 | LG DLE2532W Electric Dryer
Not Drying
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Oct 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE Profile DPSB619ED Electric Dryer Logo
338 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
