Question about ASUS Eee 4G Notebook
One of the screens that opens up isn't big enough to view the entire screen and I can't scroll down on the screen (there is no scroll bar) - do you know how to fix?
Scroll bar won't work on some e mails
You need to fix IE8 to have it work properly with GMail, by turning off Compatibility View. 1. In IE9, press the Alt key to toggle the main menu bar on first.
2. Then in IE8 or IE9 click Tools and choose Compatibility View Settings
3. Remove google.com from the big text box if it is there (in some versions it may not be.)
4. Uncheck the three checkboxes under the text box - this is very important, or Microsoft will just switch CV back on again next time you start IE.
5. Restart IE.
That should cure all your scrolling problems.
To deal with your sidebar you have three options:
1. Hover your mouse over the section you want to see to expand that part - i.e. mouse up to your labels to have them all drop down, or mouse down to the bottom to see your Chat contacts
2. Grab the bar which divides the two sections and drag it down till you can see all your labels
3. Collapse Chat till you need it by clicking the Chat bubble icon at the bottom of the side bar.
Jul 29, 2016 | Dell Computers & Internet
How to make email fit entire screen so it is larger
new message window in Yosemite Mail is way to big for a small ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Oct 17, 2014 - I have a problem with Mail (Version 8.0 (1990.1)) since I have updated to ... the window of the new email opens so large that it s not fit on the screen on my Macbook 13". ... The new-message-Window covers the whole screen.
i can't resize the new message window in mac mail. ' Apple Support ...
Apple Inc.Jan 3, 2014 - It opens up as big as full screen or bigger. .... I have several emailaccounts set up within Mail and have the "Bcc" field set up so I automatically ...
My window is too large and wider than my screen. How do I ...
https://askleo.com/my_window_is_too_large_and_wider_than_my_scree...
Apr 20, 2006 - Now when I open an email thru Outlook it's hug. ... to slide the window arround on the screen to see those portions which do not fit. .... my screen is too large, i cannot get it to minimize, all of the info is at the top. i ..... Same goes with Garage Band and Safari... in fact my whole computer display seemed to go ...
Emails are now too large, don't fit to screen and scroll bars ...
productforums.google.com/d/topic/gmail/gyrz7_MEj2c
Google
Jul 13, 2013 - 4 posts - ‎3 authors
... to the gmail style, many emails are now too large and don't fit to screen. ... This never happened with the older version and it is not easy to deal with. ... area to the right, then scrolling is required to see the entire message.
Jan 05, 2016 | Tablets & eReaders
How do I see an entire page at once on my monitor?
does this only happen to web pages ?
for a general web page
right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
if you select the view tab at the bottom of the drop down list select full screen
if you need more help with this post a reply
hope it helps
Aug 07, 2012 | Gateway Lt2805u Netbbok
How to brighten the screen during internet usage with galaxy s3
While in browser, open settings (bottom left button) and change display setting. The s3 has separate display settings for browser and general phone. Hope this helps.
Jun 02, 2012 | Samsung Galaxy S3
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
Hey i have a sony vaio notebook and am having trouble scrolling down on an open page that is too big for the screen some pages have no down arrows on the side and was wondering if any one could help thanks
Check if the Scroll Lock button is on or off. ( If you hit the Scroll lock button, the light will glow, it means its On )
Turn it off and you should be able to scroll.
If this does not help, the file or page you are viewing should have a HAND option to let you view the page or browse through it without the arrow keys
Oct 21, 2010 | Sony VAIO Notebook
Can't read boottom of the screen
right click on desktop left click on properties
go into display settings tab on the right
change the pixel setting to 1024 by sliding
the bar , you may have it set on something bigger,
Dec 17, 2008 | ASUS Eee 4G Notebook
SCROLLING LINES AT BOTTOM OF TV SCREEN
need replace the capacitors at side of the ic vertical marked on the , init to the big first.
Jan 11, 2008 | Apex Digital AT2708 27" TV
ASUS Eee 4G Notebook Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
