Question about Maytag LAT3600A Top Load Washer
How do I check washer specs?
Hi there, am looking at buying a used top loading washing machine, maytag LAT9704AGE, and want to confirm specifications. How can I check year of manufacture, capacity, etc? And if this particular model is prone to problems? Have google model number, can't find anything. Thanks Denise
  • denise karena Mar 29, 2007
    Very obliging operator. Have bought washing machine so fingers crossed it all works out.
    Have also contacted Maytag. They said there were no particular problems with the model and that I will have no trouble getting parts so thanks for the great advice. Denise
  • 944 Answers
They made this model apparently between 2002 to 2004, it is specified as 10kg capacity. If you end up getting it then here are some parts diagrams for the model that may come in handy; http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LAT9704AGE&mfgModelNum=LAT9704AGE&fkMfgID=1 I'm afraid i have had no luck with a manual, but this link shows an auction of one near you from a couple of weeks ago - you may get an idea of what people think and what it's worth http://www.trademe.co.nz/Home-living/Laundry/Washing-machines-dryers/auction-90916298.htm Maytag appliances are normally above average in quality, found nothing specific about particular faults with the model which probably means it is pretty reliable. You could also ask maytag - they may be helpful - please let us know the results if you try them; http://www.maytag.com/support/contact_us.jsp Hope this helps :)
Posted on Mar 24, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 29, 2007
    You're welcome - thanks for the feedback - it might help someone else
    Hope you don't need us again for the washer, but we're here if you do :)
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
This was will go through the whole wash cycle until it come to spin the clothes out then it will just stop it will not ring the close out. What can be the problem?? Please help me so that I don't have to...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 30, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Maytag Atlantis Clothes washer. Unit spins but clothes remain very wet. Where do I start to look for the problem???
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 03, 2010 | Maytag Washing Machines
I have a maytag washer and it washes but will not rinse or spin, what could be the problem ?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag bravos wont spin out
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer belts running but tub not spinning
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Jul 10, 2010 | Maytag Atlantis MAV7551 Top Load Washer
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why did the Q6 component blow on the circuit board
I`m not sure which component you refer to by "Q6", but typically on the Maytag Neptune washer it is the resistors associated with the door lock assembly which burn out on the "machine control board" (not to be confused with the "motor control board" located under the basket/tub inside the cabinet). It should look like the image below.
You can usually examine the control via a visual inspection to confirm or dismiss any damage. Look for any sign of burnt resistor's, specifically one identified as R11 and one as R75 they are both part of the lock circuit and if damaged will prevent the washer from draining and spinning properly because the door lock won't engage. The control will need to be replaced if damaged as will the latch wax motor. (Unless you can identify the value of the resistor`s and take a gamble on a repair)
Check with a local or on-line part depot with your model number for specific part number's. Hope that help's, let me know. Thank's for visiting "fixya" and if this was helpful please leave a rating for the info I provided. Thank's again and good luck. macmarkus :)
Feb 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Best washers ?
the larger capacity maytag with the larger gears in the transmission can break. the standard transmission on some of the ge are bad, the coupling breaks in the kenmore and whirlpool if you overload.
I still like maytag the best and I have been in the appliance business 19+ years
Dec 14, 2008 | GE WBSR3140DW Top Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Maytag LAT3600A Top Load Washer Logo
495 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
