It says damaged,or incorrect code,when i put a cd in it just spins and then stops and i get nothing
SOURCE: Unknown cd-dvd rom driver for Acer Aspire 5100
control panel add new hardware
follow instructions choose yes already installed if a box appears scroll and see if your cd drive is there if so highlight then next.
If not showing scroll highlight add new then next choose option automatically install.If still not installed then go back and if you know your cd type choose option select from list then highlight what your looking for then next choose type and model from the list and next
how old is the system maybe you need a new cd rom.
Have you made any changes to your system when this start to happen
SOURCE: My CD/DVD player on my laptop wont work???
go to my computer and right-click on your drive and say autoplay, does that work?
SOURCE: power lights come on the fan spins battery charges, but nothing else works
This sounds very much like a dead motherboard. I would suggest you get a professional to look at this or send it to acer. Visit thier site if you wish to. I would offer more help however laptop parts are expensive and tedious to replace.
SOURCE: my cd rom doesn't work, it comes up with code 39,
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Hope this helps
SOURCE: My acer Extensa 5620Z DVD/CD ROM drive is detected
That is a Vista problem with ACER. Delete the reference in device manager and restart and let the comp reco0gnize and reinstall ...just follow the screen instructions.
There is a registry setting that needs deleting but only if this doesn't work.
