Question about KitchenAid K45SS Classic Stand Mixer
Black Residue on meat using Kitchenaid meat grinder attachment
I recently started using the Kitchenaid meat grinder. After about a hal a pound goes through, black residue is all over the meat. When I take it apart, there is tons of oil-like back gunk in the meat chamber. I was hoping it may just be a one time thing, but this is the 4th batch of meat I have made and it has just gotten worse. I see others are complaining about it (eg. on Amazon.com reviews). It is coming from inside the machine where the grinder attachment fits into the machine. Second question: Does this happen with regular meat grinders also?
  • Anonymous Mar 18, 2014
    what type of oil should i use?
The guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
  • 145 Answers
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Posted on Jul 08, 2009
  • 3 Answers
In most instances, it has a lot to do in the way you clean it. Don't lace it in the diswasher because it with become somewhat 'tarnished' where black-like suit can rub off, and coat the meat.
I discovered Palmolive oxy dish soap (blue bottle) just by trial and error. Put some on a sponge/ (non-metal) scouring pad, and scrub the attachment, it will take off the majority of the gunk that's rubbing off and after a few times of cleaning it, it'll get back to its aluminum luster. Easy remedy to clean any aluminum item.
Posted on Sep 19, 2009
  • Audrey Young Nov 17, 2011
    I am having the same problem when trying to make pimento cheese. The grinder is clean and as I continue to put the cheese in, black sludge starts coming out of the holes along with the cheese. What does kitchenAid recommend?
    kwlts@ntelos.net
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
No i'm only looking for attachments for my kitchenaid mixer model no. ksm90ww
State your country and someone will direct you. What is a batter blade, is that the flat paddle or a dough hook?
Jan 08, 2015 | KitchenAid Food Mixers
Where can I get the service manual for this model?
Hi, Bricklayer.
You can find the parts diagram here: http://www.mendingshed.com/ka6pro.html
And you can order replacement parts there.
How old is your mixer? There was a time that they shipped with a plastic gearbox, and it frequently failed. Kitchenaid went back to all-metal parts after a while.
I have the same issue, but there were no parts - just an attachment drive gear that does not turn.
Mar 22, 2013 | KitchenAid KP2671 Professional 6 Series...
I was using meat grinder attachment and stand mixer stopped running
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
Dec 02, 2010 | KitchenAid Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Mar 19, 2008 | Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
4,197 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
