Question about Kenwood DDX-6019 Car DVD Player
Kenwood DDX6019 No Sound with CD/DVD
I have no sound when I play DVDs, or CDs. I can click over to FM and it is fine, when I go back to DVD, no sound. The video is fine, and with a CD, it says its playing. I have read the effin manual 1000 times. What gives?
  • Jeff Smith Mar 24, 2007
    power ant wire and remote amp wire switched.
  • 14 Answers
It is what Turbo911 stated. If you switch the solid blue wire (powere antenna) with the blue&white wire (power control) this will solve the issue. The blue wire is made to power an antenna in which is only used when on FM source. When this is connected to amps, it will shut off your amp as soon as you leave FM radio
Posted on May 07, 2007
Haha retards depends upon the car odds are the simplist way to explain it is that you have a factory amplifier this means that the amp is turned on in the car when power is sent down the power antenna lead to your car. most likely you have something european bmw, vw etc. but any ways the simplist way to fix it is to attach your amp remote turn on lead to your factory power antenna wire. this doesnt mean you wired it wrong like the guys who apparently know everything.... who i would let touch my car with a ten foot pole. now if you also have amps in the car you will need to still use the amp remote turn on wire to power them. the power antenna lead will not work. the problem is that you dont want to hook too many things into this wire because like all the others on the harness it more than likely has a 7-10 amp load rating on it. so try that and it should work for you
Posted on Apr 20, 2008
Playing cd's no sound from the speakers when I have the cd/dvd option selected. When I put the reciever on I can hear dead air coming thru the speakers but not when I have the cd switch selected....
You need to find the manual and/or read and understand every indicator and evaluate how it affects the sound. Use a medium volume setting while troubleshooting.Check connections.
Start with the basics. Speaker test ok? FM ok. Digital sources assigned yada yada.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-8060-Receivers-manual/id/480ci254/t/2/
Jun 30, 2011 | Kenwood VR-8060 6.1 Channels Receiver
What is mean by troubleshooting?give some examples.
Troubleshooting simply means, investigating a problem to find out the cause and to fix the problem. We can also say; the process of finding and fixing a problem is called troubleshooting.
Example like when your computer has sound problem, we have to find out what is the cause, suppose if it's drivers related problem, after installing or updating the sound drivers will fix the problem so here, installing and updating the sound driver is the Fix.
If you cd/dvd player isn't playing your Cds/Dvds, you have to check the media (cd and dvds), after that, you'll also clean the cd or dvds. And if your cd/dvd problem is caused by the Lens not the others like cds or motor, etc.., then replacing the lens will fix the problem and there'll be no more problem with your cd/dvd player. I'll read and play all cds/dvds after the lens is replaced.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
The CD drive only plays DVDs and will not read CDs. When a CD is placed in the drive, the drive begins to make a weird clicking sound and eventually will stop trying to read the CD. But when a DVD is...
the dvd drive needs to be replaced cause the laser is getting weak which is why it will read dvds but not cd's. Once you replace the drive you won't run into that problem.
Jan 23, 2010 | Sony Computers & Internet
DVD-player won't play DVDs, but reads CD/DVDs for programs fine..
Could be a codec problem, try downloading the codecs from codecs.com
download the codec pack for your OS.
Jun 26, 2009 | Computers & Internet
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 13, 2009 | LG GSA-H55N DVD-RAM Burner
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Kenwood ddx6019
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
May 25, 2008 | Kenwood DDX-6019 Car DVD Player
No sound from anything but FM
Disconnect whatever's connected to the blue wire behind the unit, and re-connect it to the blue/white wire instead.
Aug 05, 2007 | Kenwood KVT-617DVD Car DVD Player
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
Kenwood DDX-6019 Car DVD Player Logo
401 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
