Question about Bosch HBL 5056 Electric Double Oven
I have a Bosch double oven and the light is out and how do I get the cover off to replace the bulb?
  • palbe74721 Dec 19, 2008
    Could not get the cover off
  • 8,197 Answers
To change the light you need to unsreew lt lens then pul the bulb straight out to you. then reverse the steps to put back together.
Posted on Dec 17, 2008
Have a Bosch built in Oven, cannot release glass cover to replace oven bulb
Take a look at www.espares.co,uk where they have some videos explaining the different fittings....
On some the glass cover unscrews and on others there is a screw and cover plate that needs to be removed..
Apr 16, 2017 | Bosch Ovens
Why don't oven lights work?
The switch on the oven for the lights may be bad or the panel fuse has blown
Feb 20, 2016 | Bosch HBN 755 Stainless Steel Electric...
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
We are trying to replace the lamp in our Bosch Double oven but are unable to unscrew the lamp cover. The oven is very new but the Manufactors service agents dont want to know. Any guidance would be very...
Hello Graham,
The lenses unscrew anti-clockwise, but they can be very stiff and difficult to grip. The best advice I can give you is to double or triple wrap a thick elastic-band around the lens as this will give you much better grip than you will get on the glass alone.
If you are still unable to unscrew the lens, squirt a small amount of WD40 / penetrating fluid down the back of the lens so it runs onto the threads and leave it for 15-20 minutes then try again with the elastic-band grip. Once the lens moves a small amount it will unscrew relatively easily. The constant heating and cooling of the oven causes them to lock.
Please switch off the power supply to the oven before replacing the bulb and make sure you have clean hands when replacing the bulb - grease from your fingers can cause the bulb to fail or shorten its life considerably.
Hope this helps. If you are still unable to unscrew the lens, please let me know.
Regards,
BElectric.
Apr 12, 2011 | Bosch HBL 5056 Electric Double Oven
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to...
take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Jul 31, 2010 | Bosch HBN 9061 / HBN 9021 Double Oven
I can't get the bulb out of my bottom oven. It is
THEY LIGHT NORMALLY UN SCREWS ANTI CLOCKWISE HERE IS A LINK TO THE BULBS AND YOU MIGHT FIND THIS VIDEO HELP FULL
You-Tube video "j3TPHgf1MRg" placeholder (do not delete)
Jan 12, 2010 | Bosch HBL 5056 Electric Double Oven
Can i replace the oven light myself on the double wall oven,hbm43b550a ?
Yes your owners manual will show how.Replace the bulb with a similar bulb{ heat resistive}
Sep 28, 2009 | Bosch HBL 755 Stainless Steel Electric...
Light Bulb
open the cover ,unscrew , replace the bulb return cover ,then ok
Dec 23, 2007 | Whirlpool GSC308PR Electric Double Oven
Bosch HBL 5056 Electric Double Oven Logo
692 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
